05-06 evo factory 2 step
Old Mar 29, 2009 | 05:30 AM
darrell's Avatar
I try searching for it on the forum but i know there is a factory 2 step switch either on the clutch pedal or underneath the dash i want to take the switch off but dont remember where it is again do someone have a pic of where it is only 05-06 evo have it 03-04 you had to get flash for a 2 step.
Old Mar 29, 2009 | 06:15 AM
jmelocik's Avatar
I'm not sure if I 100% follow what you are attempting to do but the upper clutch switch is the one that allows the stationary rev limiter to function, the lower switch is the one that, when disconnected allows the car to be started with depressing the clutch.
Josh
Old Mar 29, 2009 | 06:28 AM
racer135's Avatar
All evos have it. Some are not enable in the ROM (03-04). If you want to remove it just flash the ECU and set your 2 step higher than your rev limiter. It takes 2 minutes to do the whole thing including the reflash. Very easy to do. Dont mess with the switches unless they are broken.
Old Mar 29, 2009 | 06:40 AM
N3VO's Avatar
as he said above through ecuflash will be the easiest.
Old Mar 29, 2009 | 01:54 PM
DSMdynamic's Avatar
is it possible to get ecu flashed for 2step with an 03 evo with stock ecu?
Old Mar 29, 2009 | 02:00 PM
kanyonkid's Avatar
yes
Old Mar 29, 2009 | 02:40 PM
Malik_EvoIX's Avatar
i have stock 2 step but my next tune i want it at 5500 is that straight will i break anything?
Old Mar 29, 2009 | 02:42 PM
Kracka's Avatar
You can set it at 5,500rpm if you want.
Justin23
Dec 13, 2016 09:03 PM
KFC-AWD
May 25, 2016 07:04 AM
evodude32
Apr 9, 2016 12:01 AM
lp_ceo
61
Feb 16, 2014 06:44 PM
