What is this?
Old Mar 29, 2009 | 06:58 PM
barneyb's Avatar
Oil pressure switch - the knock sensor is under (behind) the intake manifold stay.
Old Mar 29, 2009 | 07:17 PM
justboosted02's Avatar
right. oil pressure sender
Old Mar 29, 2009 | 07:21 PM
racetek1's Avatar
That is the oil pressure sensor.
Old Mar 29, 2009 | 08:47 PM
4G63 T's Avatar
Originally Posted by justa4banger
that is the knock sensor...mine did the samething...all i did was cut the tab an replaced it with a speaker wire terminal an took off the screw from the top of the sensor and screwed it back on with the terminal attached to it.
"The screw from the top of the sensor' thats what i saw upon inspection...
but sounds like not the knock sensor.
Old Mar 30, 2009 | 08:21 AM
4G63 T's Avatar
anymore.
Old Mar 30, 2009 | 03:31 PM
4G63 T's Avatar
Originally Posted by Bimmubishi
This is what the Evo knock sensor looks like.
where the other end connected to....
Old Mar 30, 2009 | 06:33 PM
dee_yamaha's Avatar
The above pix is the knock sensor! I think lancershop sells them for about $89.
If its easy to replace (I'm assuming its hard to get too), I would spend the $89 to replace it then log your runs see if it still knocks. Atleast you know its not the sensor and something else.
I'm also wondering if the oil pressure sending unit might have caused false information to the ECU causing the irregular knocks.....another thought is do what the other guy did, fix that sensor and log couple of runs also before going with the knock sensor replacement...just my .2 cents.
Old Mar 30, 2009 | 07:34 PM
4G63 T's Avatar
^ i was able to fix and re connect above pix....now i need to log.
Old Mar 30, 2009 | 07:37 PM
burninrubb24's Avatar
dude that is the oil pressure sending unit
Old Mar 30, 2009 | 07:40 PM
4G63 T's Avatar
anyone know if it will cause knocks?
Old Mar 30, 2009 | 09:40 PM
dee_yamaha's Avatar
Did you log any runs? if you don't like using Mitsu logger, I have Evo scan. I'll be here until Thurs if you need it.
