What is this?
Old Mar 29, 2009 | 05:04 PM
4G63 T's Avatar
What is this?
That SILVER NUT You will see this when you are standing on driver side..underneath intake manifold and uicp
attach to a black part of the engine and has wire connected to it, (which now disconnected pic 1).
Now the STORY.
Im supposed to dyno tune for 109 oct but tuner had to stop due to
multiple knocks from 3200 rpm all the way up top with ZERO timing.
My car is built 2.3 with stock head, ix turbo and 264/272 cams..
Tuner suspected something mechanical problem...after researching i was able to find What
i thought knock sensor...
The Condition i found it.
It was somewhat loose (can turn with my finger with moderate effort)
metal TAB connected was partly broke but halfly connected.
Is this the problem?
Old Mar 29, 2009 | 05:09 PM
idriveanevo's Avatar
the broken sensor tab?
Old Mar 29, 2009 | 05:10 PM
RichC's Avatar
Why don't you be a bit more specific, add an arrow or circle to narrow down WTF you're talking about.
Old Mar 29, 2009 | 05:13 PM
warp9's Avatar
Looks like the knock sensor, but I dont think it is. Any check engine light on?
Old Mar 29, 2009 | 05:14 PM
4G63 T's Avatar
lol....how i wish i can i have to ask my sis to do this...tech. challenge here.
nevertheless, that nut...what the heck is that..help!
Old Mar 29, 2009 | 05:20 PM
dude, what nut are you talking about?!?!
Old Mar 29, 2009 | 05:21 PM
Old Mar 29, 2009 | 05:24 PM
4G63 T's Avatar
^ YES Sir...you got it thats what im talking about...TAB is supposed to be attached to SENSOR
Old Mar 29, 2009 | 05:26 PM
warp9's Avatar
Is the check engine light on??
im guessing you need to buy a new sensor. i would just go to the dealer and look at a parts diagram
Old Mar 29, 2009 | 05:35 PM
SPOOLEDTSiAWD's Avatar
knock sensor
Old Mar 29, 2009 | 05:43 PM
4G63 T's Avatar
no..
Old Mar 29, 2009 | 05:51 PM
Bimmubishi's Avatar
That's not the knock sensor wire from the looks of it. There is a 2 pin connector for that sensor. That looks like a VDO oil pressure sender or something.
Old Mar 29, 2009 | 06:07 PM
justa4banger's Avatar
that is the knock sensor...mine did the samething...all i did was cut the tab an replaced it with a speaker wire terminal an took off the screw from the top of the sensor and screwed it back on with the terminal attached to it.
Old Mar 29, 2009 | 06:09 PM
Bimmubishi's Avatar
This is what the Evo knock sensor looks like.
