arp rod bolts!!
Old Mar 31, 2009 | 06:20 PM
Dragking2189's Avatar
arp rod bolts!!
im making 520 whp on my stock bottom end ,im running a gt3582r with supporting mods i will be switching to e85 and adding some more mods , my tuner stated that i can make 600whp on stock bottom end but i will be too dargerous ,i already have arp headstuds. if i install some ARP ROD BOLTS will it be worth it?
Old Mar 31, 2009 | 06:38 PM
krisdlm's Avatar
for 40 i think its cheap ins.
Old Apr 1, 2009 | 06:29 PM
xxNosTankxx's Avatar
^+1, how long of an install is it by a shop, 1-2 hours?
Old Apr 1, 2009 | 06:35 PM
AWD Motorsports's Avatar
rod bolts can only help.. We have them in stock also if you decide you need them..
Mike
Old Apr 1, 2009 | 06:46 PM
StreetThisEvo's Avatar
I ran them in my car for quite some time w/o any issues. I would suggest doing them for added safety.
Old Apr 1, 2009 | 06:50 PM
when arp rod bolts are added is it safe to run 580whp
Old Apr 1, 2009 | 07:49 PM
there is NOTHING SAFE about running 580whp on a stock motor.. Will it last longer than without the bolts, probably..
Old Apr 1, 2009 | 07:57 PM
boosted9's Avatar
yeah
Old Apr 1, 2009 | 08:09 PM
I agree ha.
Old Apr 1, 2009 | 08:11 PM
11secDSM's Avatar
Definitely do it...especially if you're spinning the motor high.
Old Aug 18, 2009 | 04:22 AM
I4UnderPressure's Avatar
Back from the dead....At one point (HP) do you recommend getting rod bolts and how easy is the install?
Old Aug 18, 2009 | 10:29 AM
TalonTuner4G63's Avatar
I think most any of the 7 bolt 4G63 engines can benefit from the ARPs after around 400hp or if you plan on spinning past 7800 regularly. Not an "easy" job, but not super tough either, but you are getting into the bottom end, so taking care and knowing what you are doing is obviously important. The transfer case and oil pan have to be pulled obviously. Maybe popping in a new set of rod bearings at the same time is a good idea if the ones in there arent in great condition.
Old Aug 18, 2009 | 11:18 AM
JKD's Avatar
JKD
I think it would be very difficult to set a HP level on when they need changed. However, rod bolts will only help out when your getting up above the 500whp range. There is no set HP amount on when the stock bolts will fail.
I'm getting ready to put my 80mm FP Red on and when I start turning up the wick, I will replace the rod bolts.
Old Aug 18, 2009 | 11:32 AM
xRoguex's Avatar
I was told - Above 7800 RPM or above 400awhp -- switch to ARP rod bolts.
Above 500 - You need more then just bolts.
Old Aug 18, 2009 | 11:33 AM
J.Js evo9mr's Avatar
Id say do it bro!
