arp rod bolts!!
Old Aug 18, 2009 | 02:16 PM
I4UnderPressure's Avatar
Originally Posted by TalonTuner4G63
I think most any of the 7 bolt 4G63 engines can benefit from the ARPs after around 400hp or if you plan on spinning past 7800 regularly. Not an "easy" job, but not super tough either, but you are getting into the bottom end, so taking care and knowing what you are doing is obviously important. The transfer case and oil pan have to be pulled obviously. Maybe popping in a new set of rod bearings at the same time is a good idea if the ones in there arent in great condition.
Wow, I didn't know that the transfer case needed to be pulled. Will keep the wick turned down until I'm ready to dig in.
Old Aug 22, 2009 | 08:48 PM
DragEvo9's Avatar
why would the transfer case need to be pulled? just drop the oil pan from what I can see..
Old Aug 22, 2009 | 09:29 PM
justa4banger's Avatar
Just the oil pam has to be removed
Old Aug 22, 2009 | 09:41 PM
CA$H's Avatar
English Racing had a car running 700+ WHP on a stock motor! Heres the kicker....it was tuned to keep the WTQ around 400whp. No issues.
Its NOT WHP on stock motor that matters most....it's WTQ and RPM's that matters.
Old Aug 22, 2009 | 09:52 PM
binh's Avatar
all it takes is some preignition to crack a piston or bend a rod...
Old Aug 22, 2009 | 09:54 PM
38six's Avatar
Originally Posted by Dragking2189
im making 520 whp on my stock bottom end ,im running a gt3582r with supporting mods i will be switching to e85 and adding some more mods , my tuner stated that i can make 600whp on stock bottom end but i will be too dargerous ,i already have arp headstuds. if i install some ARP ROD BOLTS will it be worth it?
It couldn't hurt, but it is usually done when building the bottom end.
Old Sep 6, 2009 | 04:03 PM
IF thats all that needs to be done then this shouldnt be hard. Is there too much stuff in the way to remove it? Your experiences would be helpful.
real fast
Jan 20, 2016 08:53 AM
blazar_bis
Evo X Dyno Results
48
Nov 29, 2011 03:38 PM
bigturboevo03
Nov 23, 2011 06:49 AM
turboslik
Lancer Engine Tech
Jun 3, 2006 12:04 PM
fimotorsports
Dec 27, 2004 01:35 PM
