Oil Feed Fitting? (Want to replace banjo bolt)
Old Apr 2, 2009 | 09:13 AM
Creamo3's Avatar
I'm looking to eliminate the banjo bolt that feeds the turbo from the head with a 90-degree fitting. The only problem is that I can't seem to find the right fitting and was wondering if anyone knows where i can order one at. The fitting would look similar to this, but would thread into the head and accept a -4AN oil line. I believe the threads for the oil feed into the head are 10mm x 1.25 pitch
Worst case I'll order one of these that is a straight fitting, but I prefer a 90-degree if possible:http://www.atpturbo.com/Merchant2/me..._Code=ATP-OIL1
Any help would be appreciated
Old Apr 2, 2009 | 09:20 AM
apagan01's Avatar
i like this, hoepfully you can make this work.
Old Apr 2, 2009 | 09:46 AM
ExViTermini's Avatar
I would have figured that atp would have the fitting...at one time I remember they did, as I used one on a friends car...
Old Apr 2, 2009 | 09:50 AM
Creamo3's Avatar
I was surprised they didn't have it either; I know the fitting exists as I have seen it on some turbo setups on here. Just need to find where to buy it.
Old Apr 2, 2009 | 12:10 PM
Creamo3's Avatar
ATP got back to me w/ a solution that will do what I'm looking for. They said to combine these two parts and I will be able to have a 90-degree for my oil feed. This may help somebody else looking to eliminate the banjo bolt w/ crush washers on their setup.
Combine this:http://www.atpturbo.com/Merchant2/me..._Code=ATP-OIL1
and this: http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
Old Apr 2, 2009 | 07:38 PM
I would just use a banjo fitting that has an -AN thread on the end of it, tis what I did and its worked well forever. I actually have a 3 or 4 still around if you want it.
Old Apr 2, 2009 | 08:49 PM
Creamo3's Avatar
I'm actually trying to avoid the banjo fitting as it requires the use of crush washers and I'm trying to avoid that setup. I appreciate the offer though
Old Apr 2, 2009 | 08:58 PM
CBRD's Avatar
they arent M10x1.25 i dont believe.. but i have to check...
you can find somethinig nicer than brass!
cb
Old Apr 2, 2009 | 09:01 PM
Creamo3's Avatar
cb
Show me the way and I'll be all over it
Old Apr 2, 2009 | 09:06 PM
AF-Evo8's Avatar
if you can find out thread/pitch this may work
http://www.streettunedmotorsports.co...90_adaptor.htm
Old Apr 2, 2009 | 09:08 PM
AF-Evo8's Avatar
http://www.streettunedmotorsports.co...y_fittings.htm its towards the bottom they have a few different thread sizes
Old Apr 3, 2009 | 04:18 PM
DIDYSIS's Avatar
its a 10x1.25 call your local hose shop and they can get you everything for the best prices,. thats what i did or you can order the parts from someone like
http://www.maperformance.com/evo-vii...s-accessories/
Old Apr 3, 2009 | 04:31 PM
RoadSpike's Avatar
Edit:
Didn't see your not on the stock turbo.
The stock fittings are 10mm and 12mm for the head and turbo respectively.
OakosAutomotive
165
Mar 11, 2020 06:55 AM
XTR Performance
16
Jun 5, 2013 08:16 AM
Moore Auto
Jul 23, 2012 04:59 PM
OakosAutomotive
EvoX 'For Sale' External Engine / Power
110
May 14, 2010 12:02 PM
AFI Turbo
AFI Turbo – Phoenix, AZ
Jan 3, 2009 08:12 AM
