Help!! Throttle Sticking!!??
Old Apr 3, 2009 | 10:03 PM
Appauldd's Avatar
It sounds like someone changed the program in the ECU (the car's computer). There is a function called "no lift to shift" meaning that you can hold the gas to the floor when doing a hard pull and just clutch the car to shift. Thus you don't have to "lift" off of the throttle.
Go in the EcuFlash forum and post your issue. There are some prime ECU tuners from Aus that will certainly give you a hand.
Mitch Evo7's Avatar
Originally Posted by SICK9
If you look at the BOV, is there a hose going back into the intake, or is it just coming out of the upper Intercooler pipe and thats it..
If there is a hose going back to intake it's Recirculated...
If not it is VTA..
Sounds like the clutch to me..
How much HP you got, and how many miles on the Clutch?
Typical clutch going bad, is it's revving to a high rpm when you press clutch pedal and then falling at gear change.
Do you have a video cam..
That would help alot..
If so, go video the rpm guage while it's doing it..
Checked the HKS is recircultated....
Dunno how much hp it has....its a jspec and I only got it yesterday. The previous owner imported it from Japan 1 year ago in the state its in....Only mod he reckons he has done is tint the windows other than changing seat belts/tires etc for Australian Compliance...
Oh and the clutch....
The clutch is under 1 year old and done approx 6-7000km's and it is an Exceedy Heavy Duty Organic clutch...?
Drove it into the city before and back home....(about 70kms) and it doesnt seem to be playing up now.....
DUNNO....I'll go pull the IC piping off n have a look
Old Nov 4, 2010 | 08:23 PM
OsideEVO's Avatar
Did you ever find out what the problem was cuz my is doing the same. I left off on the gas and it gets stuck. It holds anywhere between 2 to 5k rpm. Until I turn off the and restart it
Old Mar 12, 2011 | 02:16 PM
badev0's Avatar
Mine is doing this same exact thing!!!!!
Any resolutions? I think its the tune, it started doing this after new cams and turbo.
Old thread, I know.
Old Mar 12, 2011 | 02:19 PM
SAVAGEcorpsman's Avatar
It most likely is your throttle body shaft seals in collaboration with your BOV. Get a Evo 9 Diverter valve and you should be fine.
Old Mar 12, 2011 | 03:47 PM
badev0's Avatar
My car was perfectly fine 36 hours ago until the the larger turbo and kelford cam install. I have no boost leaks, and its certainly not my tial bov. Has to be the tune.
JC evo1
19
Sep 25, 2019 02:23 PM
aaronp
Feb 10, 2017 09:55 AM
mrmiller
Jun 21, 2016 07:08 PM
LeXcite
Dec 5, 2015 02:33 AM
2012XSSTMR
Oct 30, 2015 12:52 PM
