Clutch bleeding issue.
Old Apr 5, 2009 | 02:59 PM
EVO8emUp's Avatar
Directly from the manual:
4. Check that the brake fluid reservoir level stays between
"MAX" and "MIN" marks throughout the clutch bleeding
process.
My clutch portion of the reservoir does not start to fill unless the fluid level is ABOVE the MAX line. I don't know if it's supposed to be this way, or if my reservoir is funky. If the level drops below the max line (on mine), and you keep bleeding, it will suck the clutch portion of the reservoir dry.
Just figured this may help somebody that's having problems bleeding.
