02 housing
Old Apr 6, 2009 | 06:12 PM
wiggam11's Avatar
02 housing
just ordered epm 02 dump is removing the rad totally necessary i plan on doing the swap on a lift and just wanted some input
Old Apr 6, 2009 | 06:31 PM
jmelocik's Avatar
Not totally necessary but makes life a lot easier to pull the radiator, pull the complete turbo assy, do the swap and then bolt everything back in.
Josh
Old Apr 6, 2009 | 06:36 PM
19DB794's Avatar
Should help : https://www.evolutionm.net/forums/ev...sing-pics.html
Old Apr 6, 2009 | 06:54 PM
justa4banger's Avatar
its better to pull of the radiator, cuz forsure you dont wana make a hole on it..been there done that..just take it off, 2 bolts and 2 hoses and disconnect the fan and its out...
Old Apr 6, 2009 | 07:20 PM
xmaciek82x's Avatar
I just did a o2 install and I can't imagine how difficult it would be if I didn't pull the rad.
Old Apr 7, 2009 | 01:45 PM
wiggam11's Avatar
alright cool that post said 5 hours, does it really take that long? me and a buddy are doing it ona lift with all air tools def coating it with pb blaster while i remove the rad
Old Apr 7, 2009 | 02:11 PM
no shouldnt take that long specially if you have somebody helping you...
Old Apr 7, 2009 | 06:16 PM
evo unknown's Avatar
PB blast all the bolts the morning of and right before. Removing the radiator gives you a little more room, and if you're in need of a flush, do it all at once. However, you can leave the radiator in, just put some cardboard over it to protect from denting any fins.
