check engine
Old Apr 6, 2009 | 07:21 PM
MIVEC 4G63's Avatar
check engine
hey guys you probably read a few other threads i have up here but this is my problem, i did the cams and now i get the check engine light, i am getting a code 365 i think, it says "cam sensor b circuit" i tried both sensors on both intake and exhaust sides and the trigger wheel(cylinder) and still not getting anything. i don't know what else to do.
Old Apr 7, 2009 | 03:54 AM
SLO-EVO's Avatar
unplug the CAS, and the battery, reset it... then try to plug it back in... if that doesnt work, post up...
Old Apr 7, 2009 | 08:01 PM
awdrivin's Avatar
if that doesnt work, start digging into the problem..
take out the new cams and re-install the stock cams..
if the CEL is still on, check the actual sensor voltage and make sure the sensor is working correctly.
