Need Help !!!
Old Apr 8, 2009 | 10:40 AM
l EVO n's Avatar
Unhappy Need Help !!!
I have a Greddy profec B-specII boost controller and it works fine but i cant get it to set right..... i want it on 20psi (car all stock) but when i try messing with it i cant get it to spool up and go on exact 20psi it goes to 22-24psi and drops down to 20psi fast i know its extremely bad wich is why i dont want to run any tests on it until i can get it about right so help me out guys yeah....(btw 20 psi is ok right on a stock car not tuned?)
My current settings are
Set:60%
Gain:15%
Set Gain (start boost):20psi
Warning:21psi
Limiter:0
Old Apr 8, 2009 | 11:20 AM
l EVO n's Avatar
can i do 22psi on stock car?
Old Apr 9, 2009 | 04:38 AM
l EVO n's Avatar
Bump!
Old Apr 9, 2009 | 05:20 AM
JakeTheVIII's Avatar
You need to be careful. Don't just start cranking it up more and more, you're going to end up fuel cutting or something. The stock system spikes 20ish and holds about 17psi. There's going to be a little taper of the boost, you just need to adjust it the best you can. Try messing with the gain. Don't turn it up too much until you get tuned.
Old Apr 11, 2009 | 03:47 AM
l EVO n's Avatar
what does spiking mean?
Old Apr 11, 2009 | 07:01 AM
I meant that it will rise to a higher boost level, and then drop back down. It "spikes" or jumps or rises or hits a higher boost level.
By spiking I mean that it doesn't go straight to 20psi when you floor it. It "spikes" 23 or so, then drops back down to 20.
Old Apr 12, 2009 | 11:50 AM
l EVO n's Avatar
i have it set on 22psi it spikes and goes down to 22psi and it has jus a lil taper , but now it i messed with it again and now it spikes and goes down to 18 psi, what should i do?
Old Apr 12, 2009 | 12:01 PM
silver_evo's Avatar
use the stock boost control system. ECUFlash and a #59 sized pill. I have total control over my boost by using boost desired engine load and max wastegate duty cycle. Its perfect. I've never liked the profec-b with the gain and decay knobs. The stock ecu has gear ,rpm, and load dependant boost control.
Old Apr 13, 2009 | 05:48 AM
l EVO n's Avatar
i didnt understand this can you give more detail plz
