injen ic piping causing problems??
Old Apr 9, 2009 | 07:48 PM
Kemist's Avatar
So last night I took off my Injen uicp and inlet pipe and replaced it with the stock stuff. The car is quiet, pulls like a champ, psi jumped up by 2 and idles better. I realize maybe I had a boost leak but; anyone else had this issue or was I dealing with phantom knock?
Opinions appreciated.
Old Apr 9, 2009 | 08:05 PM
bambooi's Avatar
It doesn't seem like a lot of people run that UICP around here. Why do you think you had phantom knock? Did you make any logs with the car?
Old Apr 9, 2009 | 08:08 PM
N3VO's Avatar
if the stock is working better keep it on dont really see many gains from aftermarket uicp
Old Apr 9, 2009 | 08:20 PM
EvolNinja's Avatar
They just look better than stock uicp. Also less bends on some aftermarket uicp. Too bad I can't put mine back since I cut one of my alum oem uicp pipe and coupler
Old Apr 9, 2009 | 08:26 PM
R0b's Avatar
R0b
i have the kit and no probs from my side
same boost, no changes.
on the piece from cooler up to where the battery is, theres a bracket - i used a rubber washed under it to mount it. just to have a tiny bit of flexi when i go over bumps.
Old Apr 10, 2009 | 03:50 AM
Kemist's Avatar
Yea, logs indicated some knock from 2500k to 4000k, let it went away. I'm going to relog tonight and see what happens.
Good thinking , I think I'll do the same
