Wastegate overboost and boost creep
Old Apr 14, 2009 | 06:39 AM
AWD_Terror's Avatar
I dont think going to a 44mm will fix the problem at all.
There should be no reason a 38mm cant handle his setup.
Pics of the manifold please!
EDIT....... 44MM might help the problem if the manifold is improperly designed. I just thought that one through
Old Apr 14, 2009 | 07:54 AM
sekula's Avatar
edit
Old Apr 14, 2009 | 08:06 AM
AWD_Terror's Avatar
To my understanding on WG sizing.. . And Tial can confirm or deny here. . . .
But a smaller gate should work fine as long as you are not trying to hold it down to lower boost levels or the manifold is improperly designed with WG placement
Bigger WG will work in either scenario, but allow you to hold lower boost levels if needed and maybe aid in an imroperly designed WG placement.
Please post a picture of the actual manifold. Im confused now on your comments about the WG placement
Old Apr 14, 2009 | 08:12 AM
sekula's Avatar
edit
Old Apr 14, 2009 | 08:30 AM
AWD_Terror's Avatar
I am utterly confused. . . . . .
Your WG is on the 02 housing and not the collector of the manifold?
Old Apr 14, 2009 | 08:36 AM
sekula's Avatar
edit
Old Apr 14, 2009 | 08:50 AM
AWD_Terror's Avatar
i still am dumbfounded by this, but I guess if AMS sells it, it works
Old Apr 14, 2009 | 08:57 AM
TiALSport's Avatar
casting probably just needs a good port job to allow better flow to the gate
Old Apr 14, 2009 | 09:04 AM
sekula's Avatar
edit
Old Apr 14, 2009 | 12:34 PM
Shearer's Avatar
What turbo is on it?
Was the exhaust housing ported out to match the o2 housing? If not it will surely creep.
Old Apr 14, 2009 | 01:43 PM
sekula's Avatar
edit
Old Apr 14, 2009 | 04:06 PM
Shearer's Avatar
Get the housing ported and it will take care of the creep issue. The hole in the turbine housing is severely undersized to work properly.
Old Apr 30, 2009 | 02:18 PM
Gamble's Avatar
Originally Posted by sekula
It's a Shearer manifold. It has the wastegate off the 5 bolt o2 housing though. I don't think the manifold has anything to do it. It might need a bigger wastegate because the 38mm might not be able to get all those exhaust gases out and the extra gases are spooling the turbo up more than needed...
It is a 6262, and the exhaust housing came directly from Precision so it wasn't touched, and I'm assuming the o2 housing was since the hole is a little bigger in the o2 housing than in the exhaust housing, so I'm assuming the wastegate hole in the exhaust housing needs to be ported out and made more smoother and matched with the o2 housing hole. I'm going to get that done in a few weeks and let you guys know what's up.
Nice setup
Old Apr 30, 2009 | 05:08 PM
Chicago_DSM's Avatar
Originally Posted by Gamble
Nice setup
Internetz stalkin 4 tha luz
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Feb 21, 2014 07:43 PM
