Fan switch questions
I just got done removing everything from my bay on the front half of the motor.
Well my friend unplugged **** without me knowing and i put it all together and only found one plug to the bottom part of the fan switch.
Now I will say one fan is on the motor side and I have a pusher on the IC side. Im believing the side spot on that controller goes to the other fan?
Anyone have pics of the plugs or know what each plug does or where it comes out of the harness to help me what Im looking for?
Basically I let the car warm up and was waiting for the thermo to open and the fan to kick so I could put more coolant in after the work I did. Its not opening nor the fans coming on
One update. . . . . I let it run more and the slimline comes on, but not the one factory one.
Not sure it ever has though. I can only assume it has.
Any way to test? Give the fan a direct 12v source ?
idk if this is gonna help but one plug on the fan box thing plug back into the side f the same box, and then theres a big plug thats attached to the car that plugs into the bottom of the box on the fan
What i have right now is a main big plug into the bottom of the box and the plug right next to it to the stock fan.
The plug on the side of the box is open and cannot find what goes to it. I can only assume the other stock fan would plug in there?
I looked at the harness to the slimline and it looks like it routes back to the harness in a diff area.
Were the stockers daisychained together somehow?
Sorry if I sound stupid. I bought the car with most of this stuff done and trying to figure out what the hell this kid did.
k i just went and looked at my set up, the front fan on the IC side is for the A/C condenser not to do with the rad set up, and wont turn on till needed... andthe side port of the rad control box is left open nothing plugs into it
Alchem1st
Mar 15, 2022 08:47 AM
Chamama
Mar 2, 2006 09:09 PM
