Dirty MAF Sensor?
Old Apr 12, 2009 | 02:52 PM
2006gsxr1000's Avatar
Dirty MAF Sensor?
Searched the forums some and couldn't find a direct answer. Is is a good idea to "clean" your MAF sensor every now and then. If so how do you go about doing it without killing it? I was curious as I have heard of some people doing this.
Thanks.
Old Apr 12, 2009 | 03:23 PM
hanahawaiian's Avatar
Go Schucks, Autozone. or auto supplies.. get CRF or CFR MAF and sensor Cleaner in Spray can. about 5-7 buck a spray can.. make sure unplug and take out and spray then let fully Dried then put back together and plug it up...
i did many time.. it work perfectly
Old Apr 12, 2009 | 03:27 PM
compscibOi's Avatar
What are the symptoms of a dirty MAF? How often shall one clean it? I might do this.
Old Apr 12, 2009 | 03:59 PM
GEJEN's Avatar
first use this
on this
and you should end up with...
Old Apr 12, 2009 | 10:08 PM
compscibOi's Avatar
Once again, what are the symptoms of a dirty MAF sensor?
Old Apr 13, 2009 | 07:43 PM
Thanks people. I would like to know what symptoms are linked to a "dirty" MAF sensor as well. I know what happens when they go bad, but is it necessary to clean them. Preventative maintenance?
DagYo369
Feb 10, 2013 12:03 PM
Heebs 09gts
Lancer Engine Tech
Jan 21, 2013 07:27 PM
AustinB768
Jul 21, 2012 02:12 PM
Appauldd
Mar 2, 2009 03:49 PM
TKEVO
16
Sep 18, 2007 09:20 AM
