MAF sensor ?
Old Aug 23, 2007 | 10:37 AM
TKEVO's Avatar
Veteran: Air Force
MAF sensor ?
I had a mechanic look at my evo and he said that the MAF sensor on the intake may be bad and could be my reason why it is running a little ruff. Could this be true? What are some signs of a bad MAF sensor?
Old Aug 23, 2007 | 09:42 PM
TKEVO's Avatar
Veteran: Air Force
bumpppp
Old Aug 23, 2007 | 09:55 PM
sparky's Avatar
When was the last time that you installed gapped, fresh plugs?
Old Aug 24, 2007 | 10:41 AM
TKEVO's Avatar
Veteran: Air Force
in june when I got it tuned. We checked the plugs, they r good
Old Aug 24, 2007 | 10:43 AM
smokedmustang's Avatar
Bad MAF, runs rich, get MAF cleaner first.
Old Aug 24, 2007 | 10:45 AM
TKEVO's Avatar
Veteran: Air Force
Where can I get that at? MAF cleaner
Old Aug 25, 2007 | 05:54 PM
I think Pep Boys, or Autozone. It is called "CNC"? MAF cleaner. Red can i believe. Get that, not other junk! Sorry for the late reply! Good luck, and keep us posted.
Let us help, what is "Rough"??? What and when does it do it?
Old Aug 25, 2007 | 06:46 PM
There is a photo of the can here:
https://www.evolutionm.net/forums/sh...=262136&page=3
Old Aug 26, 2007 | 08:51 PM
TKEVO's Avatar
Veteran: Air Force
Cool I will go check that out. What I mean by rough is it jerks at times. It has done it when im cruisin at 30mph. 1-3rd gear is when it happens the most. It rides as if my plugs were bad but they are basically brand new. They were installed in June while it was getting tuned.
Old Aug 26, 2007 | 08:56 PM
Cirrusly Evolvd's Avatar
Pull your plugs and check them out...just cause they are new doesn't necessarily mean they are good.
And electrical parts cleaner or "Contact" cleaner will work. Even brake cleaner works.
Old Aug 26, 2007 | 09:30 PM
TKEVO's Avatar
Veteran: Air Force
Plugs have been checked and r good
Old Aug 26, 2007 | 10:50 PM
Neuspeed06's Avatar
What is the sign that the MAF is dirty? I have timing issues due to the MAF it seems, but it looks clean when i look into it....Signs of dirty MAF?
Old Aug 27, 2007 | 10:07 AM
TKEVO's Avatar
Veteran: Air Force
Yea thats a good question, what is a sign of a dirty maf?
Old Aug 29, 2007 | 08:34 AM
You pull it out, look at it and see grime/dirt on the sensor....
Driving signs are hesitation, spotty idle and possibly many other things.
Old Aug 29, 2007 | 10:13 AM
TKEVO's Avatar
Veteran: Air Force
U know what, that sounds exactly like my problems. Thanks. I will let you know if that worked.
