Car stuttering on WOT.
Old Apr 13, 2009 | 12:11 PM
TxEvo8's Avatar
Dude, change ur plugs! It's cheap and takes only 30 mins, anybody can do it...
Old Apr 13, 2009 | 12:25 PM
Koroshiya's Avatar
Yeah I can't find a shop around here that has them in stock.. guess I'm going to have to order and wait!
Old Apr 13, 2009 | 01:25 PM
heel2toe's Avatar
thats your best bet. Get yourself a set of new plugs, properly gap then and report back. Their pretty cheap in comparison to other things, are extremely easy to swap out and they can only help Keep us posted
And im a little confused with what your saying about your clutch. Are you saying you may have fried it only after 5000 miles? If so, either it was installed improperly or you sir need to improve how to drive a stick
Old Apr 13, 2009 | 01:26 PM
E VOL IX's Avatar
sparkplugs.com chris... denso ihk24 or ikh24...
Old Apr 13, 2009 | 01:54 PM
matt55's Avatar
I think it might be my clutch...
I have about 5k miles on my clutch.. but here's the problem.
On the way to work today I tried the "5th gear test" I essentially put the car in 5th gear while rolling at 35mph. It was stutter for a second then the RPMs would shoot to redline. This really blows since I just got this thing installed!! I've been complaining about how hard this clutch is to drive since I got it, I also found that the t-case was leaking oil. Once I tightened that up and put in new oil, the clutch started feeling better. But now I'm afraid the damage is already done.
What do you guys think? What should I do if it is the clutch. Should I replace the whole thing, or just get the replacement wheel or whatever it is... (Not sure what it's called.)
Or do you still think it's the plugs? :-P
maybe sparkplugs
How fast did you get up to that 5th gear test @ redline like 55 mph or 120ish .
If only 55 or so the clutch sound gone .......
Old Apr 13, 2009 | 02:36 PM
Koroshiya's Avatar
It was only 55mph or so no where near even 70...
Old Apr 13, 2009 | 06:29 PM
EiEVO's Avatar
Sorry bud but your clutch is slippin...
Old Apr 14, 2009 | 03:43 AM
crewdawg130's Avatar
You still think it's plugs even after my last post?
you having 2 problems. Change the plugs and do the test again.... But i think your clutch slipping. give justin a ride he'll tell ya.
Old Apr 14, 2009 | 08:35 AM
alloutDSM's Avatar
still try out the plugs bro even if you dont have the new one's yet you can pull one out to see how bad they look.
Old Apr 14, 2009 | 04:52 PM
Koroshiya's Avatar
Justin just gave me the verdict.....
I don't even want to go there.
Man I need to get my post count up.. Someone ask me a question. Preferably one I can answer. So don't ask me about cars!
Old Apr 16, 2009 | 04:58 PM
....get some plugs and jmill and me will check it out for ya
Old May 7, 2009 | 09:10 PM
cookster116's Avatar
My 05 Evo 8 is stuttering bad. I can floor it and at 15.5 pounds of boost /5.5 rpms it start stuttering. I have put all 3 NGK sparkplugs in the car this week. I have changed the egr valve, and all the vacume and boost lines. my sparkplugs gets black after about 15 miles. it is getting bad. yesterday it was doing it at 21 pounds of boost. here is what I have done to the car. • Turbo back exhaust ( HKS 3 Inch)
• Down pipe wrapped
• Test Pipe
• Hollman (blue) Internal boost controller
• Forge wastgate
• Steel braided oil turbo line
• Custom air intake Piping
• K&N air filter
• APS 50/50 blow off valve
• Intercooler (31 inch x 12 inch x 3inch)
• Nitrous Express N-tercooler Kit (co2)
• Zex dual outlet nitrous purge kit
• T-clams
• Injen Lower Intercooler pipe
• Hard upper intercooler piping
• HKS 272 intake & exhaust cams
• Fidanza cam gears
• Brain Valves
• Brain Valve springs
• APR head studs
• Magnecor 8.5mm spark plug wire set
• Custom spark plug cover
• 255 Walbro fuel pump
• OBX fuel rail
• 780cc injectors
• Fuel pressure regulator
• Light weight Pulleys
• ACT Light Weight Flywheel
• Stage 4 Clutch ACT
• Mr. gasket intake gasket
• Mr. gasket copper exhaust gasket
• Torque dampener system
• Solid Shifter Bushings
• AC. Delete
I did check the timing and it is good now what!!! Please help me!!! thank you
Old May 8, 2009 | 01:23 PM
• Down pipe wrapped
• Test Pipe
• Forge wastgate
• K&N air filter
• T-clams
• Fidanza cam gears
• Brain Valves
• APR head studs
• OBX fuel rail
• 780cc injectors
• AC. Delete
Do you have a wideband
Old May 8, 2009 | 01:37 PM
yes I do. the fuel is never the same and it is tuned by Jesters tuning. I boost 24 pounds. I am going to check the codes right now
Old May 8, 2009 | 01:40 PM
whats the AFRs around 5.5k on average
