swap i/m and t/b
Old Apr 14, 2009 | 08:04 AM
ch53avitech's Avatar
swap i/m and t/b
How hard is it to swap the intake manifold and throttle body? I have spare manifolds (intake and exhaust) and a spare throttle body, I plan on sending them to BR. Theres nothing to the exhaust manifold, thats a straight forward swap. So how hard is the t/b and i/m? I read somewhere that it's a PITA.
Old Apr 14, 2009 | 08:13 AM
C6C6CH3vo's Avatar
At your current WHP, replacing all that stuff you suggested might not be worth the gains, perhaps losses, and not to mention work and money involved. Unless you are setting up for a turbo upgrade.
Old Apr 14, 2009 | 08:15 AM
Evo8Emperor's Avatar
I think its pretty easy myself. For the underside flange bolts its best to use a wobble extension but a regular one will do. That and take the bracket off underneath first.
Then its a matter of unplugging the sensors and vacuum lines. I personally removed all the sensors and vacuum lines and have them on a separate plate disconnected. I also bought a vacuum block to make things a little cleaner. Before you send it to BR you should clean up all the unused bungs thats if you want a cleaner look.
Old Apr 14, 2009 | 12:54 PM
riceball777's Avatar
its very hard and it sucks
i remember when i did this myself. 10x harder on the evo compared to my integra
Old Apr 16, 2009 | 11:20 AM
I'm setting up for a HTA86 or such. Or a Red after I play with the 9 turbo first. I'm also saving for a BR block to handle the power.
Old Apr 16, 2009 | 11:27 AM
lexat20's Avatar
It is time consuming but not difficult. The bolts on the bottom of the mani connecting to the mounting bracked are a pain to get to but with a little patience it can be done. I had mine off in a little under 2 hours and back on in another 2 hours. I always take pictures of everything before I begin only to help remember where everything goes.
