Diagnose my Exedy Twin please
Just pulled my Exedy twin SD out, and it looks pretty jacked.
I only bought new discs to rebuild, what do I do about the floater plates/ pressure plate? Can I resurface the floaters? Or what do I do?
It seems one disc wore out uneven on the ouside, the other disc looked even.
Thanks in advance.
-Devin
PP
Floater closer to PP
Thanks in advance.
-Devin
PP
Check if your input shaft is bent. My car is a 03 and had a bent input shaft and the end of the clutch portion. See JackTransmission. Placed a new input shaft on the tsb and new 5th gear for this input shaft and no more problems with my clutch (uneven wear). I have a input shaft (new version)
Luis
Luis
