Clutch Help Needed?
Old Apr 16, 2009 | 03:28 AM
monkey_187's Avatar
I Need HELP fast!!(clutch area)
Here is the thing I was driving to the store and then I get to a red light and my clutch pedal falls to the floor when I push it. It doesnt want to come up I have to pull it back up with my foot, then it would work. After 3 times of doing that it falls to the floor and doest come back up even if I help it. Now the pedal goes all the way to the firewall and an back as if its just a hanging pedal.
There are no leaks or cables broken at all, my fluids are good and not low. What can it be, I need help!!!!
Old Apr 16, 2009 | 06:47 AM
blownevo's Avatar
Have u tried bleeding the system? Maybe an air pocket?
Old Apr 16, 2009 | 06:52 AM
binky's Avatar
Could also have blown you clutch slave cylinder. Check the slave cylinder, by having someone watch what happens when you push the clutch in, see if the clutch fork moves. Also as said above, check to make sure there is no air in the clutch line.
-Bink
Old Apr 16, 2009 | 11:31 AM
Koroshiya's Avatar
Is it the stock clutch? How many miles are on it?
Right now it sounds like a bleed issue, or leaky line to me.
Old Apr 16, 2009 | 01:00 PM
monkey_187's Avatar
It is an Exedy twin and it has about 1200 miles on it and there is no leaks anywhere.
Old Apr 16, 2009 | 01:01 PM
monkey_187's Avatar
-Bink
There is no way that I can do this cause the pedal is goes back and forth without any tension.
Old Apr 16, 2009 | 01:03 PM
monkey_187's Avatar
How do I do this, this is my first import......
Old Apr 17, 2009 | 05:14 AM
monkey_187's Avatar
UPDATE:
I started to disconnect the lines going to the slave cylinderand nothing was comig out. I stared the car and tried pushing and pulling the clutch pedal and no luck. I did notice that the acd pump reservoir was past the fill line before start up. When the car wa started the fluid goes back to normal, after a while it goes back up.
Old Apr 17, 2009 | 12:55 PM
monkey_187's Avatar
Guys I really need the some help here, my EVO is my DD.
Old Apr 17, 2009 | 01:00 PM
Mr. Evo IX's Avatar
Bad slave cylinder or not evough brake fluid for it to operate or possibly a clutch pedal so far out of adjustment that it's not allowing fluid down to the slave cylinder. The clutch works from the brake fluid reservoir not the ACD reservior, verify that you have adequte brake fluid and bleed the clutch line. By the way the ACD level up / down is normal and not related.
Old Apr 17, 2009 | 01:04 PM
monkey_187's Avatar
There is plenty of brake fluid in the reservoir, I have the lines disconnected from the slave cylinder. When I pull the cable that leads to the clutch fluid comes out.
Old Apr 17, 2009 | 05:54 PM
monkey_187's Avatar
bump
Old Apr 17, 2009 | 06:43 PM
Mr. Evo IX's Avatar
Can you push back on your slave cylinder? Check out this video from Jack's transmissions. If your pedal is too far out of adjustment fluid can't go from the master cyl to the slave cyl.
http://www.youtube.com/watch?v=vYJxQ...layer_embedded
Old Apr 17, 2009 | 07:11 PM
Mautofied.IS300's Avatar
Double check that everything is not leaking at all. I got rid of the restricter in my IS300, and although there were no leaks I needed to tighten one fitting to bring back pedal firmness.
-Will
Old Apr 17, 2009 | 08:07 PM
monkey_187's Avatar
That might be the problem, it use to be VERY hard to push back. I disconnected the copper line that goes from the slave and the flaring on the end was broken off. Now I need to wait till I get a new one to try the adjustment like in the video. Thank you very much for all the help so far.
