Engine fluid leak, need HELP!!!!!
Old Apr 21, 2009 | 02:54 AM
ODUB's Avatar
mine turned out to the be O-Ring on the speed sensor. got it all fixed up and the car's good as new now.
Old Aug 24, 2009 | 09:15 PM
Tsurugi-san's Avatar
Just updating this thread --- it was indeed the seal between the T-case and the tranny. Pulled the T-case, identified the worn seal, sent it off the Shep, re-installed stage 2 built T-case, and no more leaks. Rockin. Even re-torqued my headstuds while the build was underway.
Good to go!
Old Aug 24, 2009 | 11:04 PM
Fullybuilt_06MR's Avatar
your best bet is to take it to a shop and they will find it for you with a oil dye that they can see where is leaks from
ODUB
Oct 10, 2016 08:07 PM
ODUB
17
Jun 15, 2016 11:17 PM
ODUB
Sep 6, 2011 03:01 PM
ODUB
Apr 29, 2010 05:53 AM
ODUB
May 26, 2009 11:21 AM
