Just Got 272 hks cams, my thoughts!
Old Sep 28, 2003 | 02:58 PM
Turbo-Weapon's Avatar
In Timeout
From: My name is Ananda Robinson.Stupid people should be killed. i live in Maryland
Originally posted by silverfast
if you drive it everyday and in stop and go travel, the extra 12 hp its not for me IMO
If you never plan to upgrade you're turbo you would be correct.
Old Sep 28, 2003 | 04:20 PM
5StarSuzuki's Avatar
In Timeout
Waiting on my HKS 272 in/exh and HKS Valve Springs to arrive... Can't wait! Buschur mentioned aftermarket cam gears coming apart on high hp vehicles...thus I didn't buy them!
Old Sep 28, 2003 | 04:22 PM
EVOnoir's Avatar
Re: Just Got 272 hks cams, my thoughts!
Originally posted by EvoVIIIGuy
does the E manage have a stall feature on it to help this? ohh if you are considering the change. it is well worth it, the power is awesome!
yes, the emanage has an anti engine stall feature. works well from what i hear.
Old Sep 28, 2003 | 06:17 PM
silverfast's Avatar
__________________
I do plan on upgrading my turbo but im not doing a 25g.. i road race so i am looking for mid power not top power (imo)
Old Sep 28, 2003 | 08:41 PM
EvoVIIIGuy's Avatar
So the E manage did solve your problems AVATAR!! That makes me happy to hear. I have not had a stall here and was driving around all day! and the Idle never even dropped a little,, but.. it is only 48 deg out today,, wait till it gets hot again,, it will be stallin,, i gota get me an E manage!!!
Old Feb 18, 2004 | 03:12 PM
umiami80's Avatar
All you haev to do is advance the timing if you use 272's, its all in the tune to get them to idle, will it be perfect (STOCK) no, but certainly streetable.
Old Feb 18, 2004 | 03:33 PM
Turbo Strompf's Avatar
i dont know what all the confusion and fuss is about these cams.
i have 272/272 with intake and exhaust and NO cam gears.
the car never stalls! all you have to do is add some fuel at 800 to 900 rpm range and you should not have a problem.
the idle is supposed to be a little choppy but its not bad at all.
hope this helps
Old Feb 18, 2004 | 07:35 PM
4ringturncoat's Avatar
If you use the cam gears and change them with one - and one + or on having more advance or retard on on cam you ar changing the CENTERLINE...this will change how a set of cams interact with each other and how much vacuum they will pull. Back on the day any V-8 cam spec always listed the centerline for that reason.
Old Feb 18, 2004 | 09:04 PM
EvolvedVIII's Avatar
Will someone please respond as to how much these cost to install?
Old Feb 18, 2004 | 09:06 PM
should be around $250 to $300
Old Feb 19, 2004 | 12:02 PM
EvolvedfromaWRX's Avatar
would raising your idle help? my wrx idles interesting with the 660cc injectors, when i get my evo, i'll prob go hks 272 cams, im a newbie, but why would cam gears hurt?
Old Feb 19, 2004 | 01:58 PM
Deceit's Avatar
Reflashes can help correct idle problems
Old Feb 19, 2004 | 07:03 PM
Shahul X's Avatar
264 intake/272 exhaust works the best and helps keep some stockability idle?
-shahul
Old Feb 19, 2004 | 07:04 PM
Shahul X's Avatar
also.... everyone says cam gears are a waste.... with 264/272 I need valve springs and retainers?
-shahul
Old Feb 19, 2004 | 07:14 PM
Quickshift's Avatar
I am getting 272's and I willbe installing arp head studs along with buschur retainer's and springs . I dont want any of my valves to float.
