Grinding after trans fluid change
Old Apr 18, 2009 | 12:03 AM
BlackSE's Avatar
So i changed my transmission fluid for the first time at about 16xxx miles yesterday. I was on the highway tonight and my 3rd to 4th gear shift grinded on 2 separate pulls. I used Amsoil 75w-90 in the trans. Before the fluid change it was shifting fine. Do you guys think the grinding is caused by too much fluid? I may have overfilled it. Not by much but i put in 3qts with some of it spilling.
Old Apr 18, 2009 | 12:58 AM
huevosrancheros's Avatar
you cant possibly overfill it because it'll just pour right out, lol. I don't know maybe amsoil sucks. If you spilled some then your topped off.
Old Apr 18, 2009 | 05:28 AM
racer135's Avatar
Which Amsoil did you use? Amsoil MTG or other?
Old Apr 18, 2009 | 07:35 AM
BlackSE's Avatar
Old Apr 18, 2009 | 07:41 AM
bluebanana23's Avatar
did you drain and fill the correct areas? what guide did you follow?
Old Apr 18, 2009 | 07:57 AM
Mr. Evo IX's Avatar
Can't go wrong with OEM fluids for drivetrain components. I would dump it and put Mitsubishi fluids back in.
Old Apr 18, 2009 | 08:15 AM
justa4banger's Avatar
i have penzoil syncromesh and my tranny shifts like butter..
Old Apr 18, 2009 | 08:30 AM
Sully 18's Avatar
i have the same problem..but i did royal purple 75 90 ...its all i had and i was too stubborn to change it
Old Apr 18, 2009 | 01:55 PM
racer135's Avatar
Originally Posted by BlackSE
Thats the correct oil for the transmission. I am using that and have no issues.
Old Apr 18, 2009 | 03:58 PM
pls1968's Avatar
I'm using this also with no issues.
Old Apr 18, 2009 | 04:04 PM
supersupra's Avatar
after filling, you need to drive the car and then refill.
Old Apr 18, 2009 | 05:09 PM
BlackSE's Avatar
I followed the Evomoto guide and filled it through the engine bay with a funnel and tube. I'll have to check to see if I over or underfilled it, but my question is could that be the reason why its grinding?
Old Apr 18, 2009 | 06:18 PM
Jeff_Jeske's Avatar
Um.... no you don't. It takes just under 3 bottles.
I tried the above pictured AMSoil and didn't care for it either. Very notchy and crunchy when cold. I switched back to stock (($$$)) fluid and its back to feeling normal again.
I know many people run the AMSOil without issue but it didn't play nice in my tranny.
Old Apr 18, 2009 | 06:23 PM
PVD04's Avatar
That's interesting because I switched FROM stock to Amsoil because stock was too notchy when cold but the Amsoil was not.
Old Apr 18, 2009 | 06:42 PM
Jeff_Jeske's Avatar
I guess its just like everything else... when you find something you like stick with it.
