How to fix TOB clip from coming off Exedy Twin?
Old Apr 18, 2009 | 11:19 AM
R/TErnie's Avatar
I searched but could not find the solution to this problem. Evidently the throw-out-bearing retaining clip "pops" off.
Can this be repaired without removing the transmission?
Is there a solution to this problem?
I know AMS sells the push type conversion for this, is there a cheaper effective solution out there?
Thank you in advance.
Old Apr 18, 2009 | 12:08 PM
Boost3dxEvO's Avatar
Some people tried putting extra wavy clips from other clutches like ACT i believe.. but it didn't really fix the problem and those people either ended up buying a different clutch or the AMS push conversion.. I would just get the push conversion or if you don't care about having to rebuild the clutch quite often, you could pretty much pay the same money and get a full quarter master clutch kit that is already push converted ..
Old Apr 18, 2009 | 12:15 PM
555R's Avatar
ive been told the exedy twin doesnt have this issue as much as the triples
Im sure there is a fix...fyi the push conversion only applies to the 5 speed however
Old Apr 18, 2009 | 12:19 PM
It happens to both twins and triples.. and good call on the ONLY 5 speed
Old Mar 6, 2011 | 04:39 PM
playmajohn's Avatar
This is what I want to know! my clip popped off I'm about to pull my tranny AGAIN!
Old Mar 6, 2011 | 04:46 PM
fugiwara's Avatar
clutch fork stop kit?
Old Mar 6, 2011 | 10:23 PM
Highboost26's Avatar
i had the same issue with my triple .. put the clip back on and used a clutch fork stopper and it happen again .. replace the clip and added washers ... happen again .. finally broke down and purchased the push conversion .. works good no issues ...
I never popped a clip on my twin , only since i had my triple
Old Mar 6, 2011 | 11:01 PM
evilempire76's Avatar
Maybe this might help?
http://www.streettunedmotorsports.co..._fork_stop.htm
Old Mar 6, 2011 | 11:10 PM
tscompusa2's Avatar
if you popped the wedge collar off with the fork stopper then you had the fork stopper installed wrong.
Old Mar 6, 2011 | 11:34 PM
izabran's Avatar
damn this got brought back from 09
Old Mar 6, 2011 | 11:41 PM
nope it was done right .. just not a good design .. put the triple in adjusted the pedal first night clip popped ..
so far
act clutch ..not bad ..
exedy twin ...worked great
quarter master (v-drive)..lock out high rpm 8500rpm+
tilton carbon .. wears quick
exedy triple .. popped clip .. ams conversion , no problems ..
Old Mar 6, 2011 | 11:46 PM
AWD Motorsports's Avatar
OS GIKEN or AMS Push.. Problem Solved..
Old Mar 7, 2011 | 03:54 PM
94AWDcoupe's Avatar
RPS also has solution. they make a square clip instead of round that cant pop out. you have to unbolt flywheel to get back apart. smart design IMHO
Old Mar 7, 2011 | 04:12 PM
johno's Avatar
never had a problem with my exedy twin and now i have a triple with a fork stop still havent had an issue
Willott03lancer
Lancer Aftermarket Forced Induction Tech
May 22, 2015 05:05 AM
lostsoulsevo
10
Jan 6, 2014 08:35 PM
Joey B
May 17, 2013 12:46 PM
most wanted
Apr 15, 2010 08:02 AM
