Engine Overheating
Old Apr 22, 2009 | 09:30 AM
Emperor 4g63's Avatar
How much is changing headgasket roughly cost w/ labor??
Old Apr 22, 2009 | 09:54 AM
scheides's Avatar
EvoM Moderator
You keep asking more questions and not answering the ones we put back at you! Is this the newbie section?
HG job is like $700 or so. Who knows if that is really the problem though, we're trying to help you troubleshoot the problem!
Old Apr 22, 2009 | 11:49 AM
Originally Posted by scheides
If you drive the car gently, no boost, does it ever overheat? If it only overheats when you boost, you might have a blown headgasket. Do some research on this, or take it to your mechanic before it gets worse. Have you checked the coolant and oil levels? Plug change is a good idea too.
The car over heats under normal driving about 10 minutes into the ride. I haven't been boosting ever since the heating.
Old May 4, 2009 | 02:39 PM
Can having a faulty thermostat cause the engine to overheat?
Old May 12, 2009 | 11:31 AM
mishimoto's Avatar
Yes, it can. We recently released new thermostats that may be beneficial to your build as well as help your overheating issue.
Check it out here.
babaz7
10
Jun 21, 2017 08:00 AM
RaptorsMotors
Jun 16, 2017 10:49 AM
Weathergeek
Sep 17, 2015 01:04 PM
yourSpecialisT
Dec 29, 2011 06:24 PM
4G63LancerEvo
Oct 20, 2010 01:57 PM
