overheating problem!
Old Jun 20, 2017 | 04:08 AM
babaz7's Avatar
my car is overheating and i cant seem to know why..
its a new 2.1L build, i just did the break in, now getting into boost and its over heating.
the coolant reservoir tank gets drained and i have to top it up also. what can cause this overheating problem?
Old Jun 20, 2017 | 09:10 AM
EVILutionVIII's Avatar
Veteran: Air Force
Did you check for leaks?
Old Jun 20, 2017 | 10:00 AM
David Buschur's Avatar
My guess is head gasket issue. Did you burp the air out of the radiator completely? How hot is it getting?
Old Jun 20, 2017 | 10:28 AM
babaz7's Avatar
yes, there are no leaks...i bought a new cosworth thermostat, lets see if that solves the problem...
btw why would the coolant reservoir tank get drained?
Old Jun 20, 2017 | 10:37 AM
LetsGetThisDone's Avatar
Coolant res gets drained because either, the cooling system wasn't fully burped, and you had a good bit of air in it. OR, you're losing coolant internally through a bad head gasket, cracked head, or cracked block. Head gasket being the more likely culprit.
Old Jun 20, 2017 | 10:41 AM
babaz7's Avatar
hello david, what a pleasure to get your reply! big fan of your stuff, have some installed in my car too
gasket is a brand new cosworth 4g63 86mm gasket, with arp headstuds.
by burping do you mean leaving the radiator cap open and topping it up while the car is idling? if that then yes..
maybe its the thermostat gone bad or sticking, i will replace it with a cosworth thermostat.
the temp while cruising is 95 degrees C and on pulls gets upto 100+
im running the water pump adapter plate for my engine, can that cause heating issues?
Old Jun 20, 2017 | 11:21 AM
barneyb's Avatar
The standard method for filling the radiator is:
1. Insert funnel (a radiator funnel connects to the radiator in place of a pressure cap)
2. Fill with coolant
3. Idle engine until coolant disappears
4. Fill again and cap
Old Jun 20, 2017 | 11:01 PM
babaz7's Avatar
im using a 4g63 86mm gasket on a 4g64 block, can that be a reason for overheating or it has nothing to do with it?
Old Jun 21, 2017 | 12:02 AM
RightSaid fred's Avatar
You're NOT going to use an 86 mm gasket with an 86.5 mm bore?
Old Jun 21, 2017 | 01:26 AM
babaz7's Avatar
im afraid i already have, is this why its overheating?
the person i ordered from sent the wrong gasket and i didnt think much of it.
Old Jun 21, 2017 | 08:00 AM
You need to replace the head gasket with one of proper bore size.
pflores210
13
Jun 2, 2011 08:44 AM
cbarnicle
May 29, 2011 08:00 PM
11secEVO7
22
Sep 10, 2009 11:39 AM
onie
35
Aug 28, 2008 05:05 AM
sillypuddy
53
May 14, 2005 09:39 PM
