Oil Light Flickering ( I May Have Solved The Problem )
replaced mine yesterday, you def need to remove the battery and tray. To me it seemed to be located in the center of the block at the bottom, saw a pic on another thread where it was located and it showed it almost at the edge of the block on the drivers side towards the top. Def was not there...
OK, With oil fill I only use 4.3-4.5qts and I am slightly over the full line when its cold. So I don't know how I am going to run 5.4 without over filling my oil. I also need to replace the sensor I guess as tonight after several WOT runs at Idle I was flickering and it was freaking me out and only because I had blown the dipstick out twice on Thursday while driving home so now I have a throttle body spring holding it down. SO can someone post a pic of the FSM stating 5.4qts. I am also running Amsoil 10w30 Dominator switched from Amsoil 10w40 AMO. I am also on FP's Oil Return Line from the filter housing. I am running a Oil Pressure Gauge from AEM but I am tapped on the Side of the head where the large Throttle body Cable Braket is.
I think that the 5.4 is a typo. The factory owners manual says 4.5 quarts plus .3 for the filter. It says the same on alldata and everywhere else I look. It was the same for the DSMs. Everyones always just used 5 because it was so close, but never 5.4 quarts.
Thank you, I used no more then 4.5 and its slightly above the full line so I know 5.4 would be way to much.
