what does the stock evo8 diverter valve sound like?
Old Apr 23, 2009 | 07:51 PM
dairyman's Avatar
does the stock diverter valve protect the turbo against compressor surge?
how can you tell if it is working properly
my 03 evo8 sounds like it has a BOV it has a psshh noise when i let off the throttle but i no it doesnt have a BOV just the stock diverter just making sure you should hear it when it is working properly
thanks i am a n00b when it comes to evos first one
Old Apr 23, 2009 | 07:56 PM
bbyevo8u's Avatar
ok my guess is, if you dont have a aftermarket intake then your dv is on backwards!!
MuslimEvoFreak's Avatar
People got the wrong idea of what I posted! I sent you a PM of a thread similar to yours.
Old Apr 23, 2009 | 08:02 PM
dairyman's Avatar
it is the plastic one. I was reading some other threads and people mentioned that when you have a cone filter which my car has you will hear the stock diverter valve make a distinct psht tt tt tt sounds between shifts etc.
doest that sound right?
Old Apr 23, 2009 | 08:08 PM
Oki Panoki's Avatar
chill bro, if ALL your hearing is a distinct "pssh" then your good
Old Apr 23, 2009 | 08:29 PM
SLO-EVO's Avatar
spot on
Old Apr 23, 2009 | 08:39 PM
heel2toe's Avatar
well since you said that you have an aftermarket cone filter intake then hearing your stock dv is normal. If you post a pic we will be able to tell you if it is installed correctly fyi.
Old Apr 24, 2009 | 01:57 AM
huevosrancheros's Avatar
Originally Posted by spinz_4
BOV's do NOT regulate boost pressure...
They recirculate or VTA boost pressure while the throttle body closes
Old Apr 24, 2009 | 02:13 AM
cornercarver's Avatar
Originally Posted by MuslimEvoFreak
The blow-off valve regulates boost pressure. If boost exceeds a certain threshold, the valve opens and dumps the excess air to atmosphere instead of into the engine, in our case it recirculates. Are you sure you have the stock diverter valve? It should be plastic or metal if switched to an evo ix diverter valve. It might be leaking?
I hope you are joking. If not, never give advice again.
Old Apr 25, 2009 | 10:47 AM
^ I sent him an PM of a thread on here of a guy having similar problems. I just merely gave him a glimpse of what I sent him. It explains in the thread what the problem was. Sorry for making it seem like I was giving him the wrong advice. Wastegates were created for a reason. Hope you fix your problems and cheers.
Chris@nolimitmotors
447
Dec 26, 2018 04:09 PM
5k6
Mar 12, 2017 03:21 PM
itsdecker
13
Oct 1, 2016 07:14 PM
cmo-06
Apr 22, 2016 08:30 PM
Fourdoor
51
Feb 6, 2010 01:38 AM
