Head off the car, trying to take out the cams? help
Old Apr 24, 2009 | 09:27 AM
omniprobe's Avatar
I put a wrench on the cam to hold it still and then try to unbolt the cam gear but it keeps spinning.
The head is off the car so there is nothing holding it down either.
please help
Old Apr 24, 2009 | 09:34 AM
hotrod2448's Avatar
Then you're probably doing it wrong. A wrench on the cam and socket on gear bolt should be enough. Try putting a little heat on the bolt. Be sure to replace the bolt with a new one afterward though.
I did have one cam bolt that I ended up having to grind the head off because the head was stuck to the gear and the threads were really nasty. It looked like they dipped it in salt water then installed it.
Old Apr 24, 2009 | 09:40 AM
igo4bmx's Avatar
hopefully you have the head on something smooth so it doesn't damage the head surface.
leverage is your friend on this one.
Old Apr 24, 2009 | 09:47 AM
def1's Avatar
Buy a vice to hold the head down.
I was able to get my cam bolts with a wrench and a ratchet. It helps if you have another person to pull on the wrench.
Old Apr 24, 2009 | 09:49 AM
omniprobe's Avatar
Will try again. thanks guys
Old Apr 24, 2009 | 11:08 AM
CO_VR4's Avatar
Impact wrench.
Old Apr 24, 2009 | 11:17 AM
05blue8's Avatar
The cams have places on them to lock on a big wrench, just use a big one, or an impact wrench
Old Apr 24, 2009 | 12:00 PM
mini_evo's Avatar
DOnt wan tto steal your thread..... but can you do something for me?!?! can you weigh you head since you have it out of you EVO right now?!?!?
Iam trying to buy head and the guy is telling me it is to heavy to ship USPS. the limit is 70 lbs. and i cant see the head weighing that fricking much.
thanks
Dan
