Exedy twin wedge collar
So I have an Exedy twin clutch that the wedge collar is screwed up on. Does anyone know where I can acquire the parts to fix this or do i need to buy a new pressure plate.
any wedge collar should work. I just pulled out a toasted ACT but the wedge collar isn't perfect or id just give it to ya. ask an evo shop to snag you one off a toasted clutch....should be a freebie
the top right ring fits on the back side of the PP and the bottom two fit on the front the ring was on the back with the fingers from the front two sliding into it everything was so mangled I am not totally sure how everything worked
Damn I'm in the same situation. I mangled my wedge collar trying to get the TOB out of the pressure plate to get the transmission off the motor.
So no one knows where to get a replacement? Does anyone have a part number for this? My dealer barely had a clue.
