any vertical ICs out there?
Old Apr 30, 2009 | 12:45 PM
BBC's Avatar
BBC
I have a full-race vertical IC (which is sweet). I'm trying to sort out what is needed to connect the hot side to a stock turbo. If anyone has a list with dimensions of pipe and couplers it would be much appreciated.
Old Apr 30, 2009 | 12:58 PM
heel2toe's Avatar
The dimensions are going to be different depending on which intercooler ones running. Your best bet is to have the pipes custom made for your application.
Old Apr 30, 2009 | 01:01 PM
evokid511's Avatar
your going to have to figure ou the dimension of your IC then put it in place and make a custom set up connecting your IC to the turbo... your not gonna be able to just buy a kit that will fit, i doubt it at least
Old Apr 30, 2009 | 01:03 PM
evilevo22's Avatar
yeah set it up where you would like to install and customize the ic pipes too fit. Draw up what you think would work and check online for the hoses and pipes you think would work.
Old Apr 30, 2009 | 02:23 PM
BBC's Avatar
BBC
I know it's been done before. One 90 degree 2.5 pipe, one 45 degree 2.5 to 2 coupling to the turbo, and one 2.5 coupling to the i/c is what's been suggested. I know a bunch of these IC's were sold/installed last year. I just wanted to see if anyone might remember.
Old Apr 30, 2009 | 02:27 PM
Honto's Avatar
I have been running one for a year now, ill go snap a few pictures.
Old Apr 30, 2009 | 02:30 PM
idriveanevo's Avatar
what would the advantage of a vertical ic be than a traditional ic setup that is proven to work?
Old Apr 30, 2009 | 03:30 PM
xxNosTankxx's Avatar
shorter piping, less pressure loss, faster spool...
Old Apr 30, 2009 | 04:13 PM
evokid511's Avatar
when u say vertical IC do you mean that same rectanglular shape as a regular IC but the inlet/outlets are on the top and bottom?
Old Apr 30, 2009 | 05:04 PM
Click there
http://www.full-race.com/catalog_ima...erts%20(7).jpg
Old Apr 30, 2009 | 05:08 PM
scorke's Avatar
Horse and Buggies get you from point a to b.
So do ralliarts...
Scorke
Old Apr 30, 2009 | 07:18 PM
ok. for some reason i was thinking the angled mount, like ive seen on drift nissan's and stuff like that. not i can see how much shorter the flow would be, but are there any proven gains from it?
Old Apr 30, 2009 | 07:19 PM
ok. for some reason i was thinking the angled mount, like ive seen on drift nissan's and stuff like that. now i can see how much shorter the flow would be, but are there any proven gains from it?
Old Apr 30, 2009 | 07:24 PM
Sievers's Avatar
Interesting. Keep this going. I might have to see about one.
Old Apr 30, 2009 | 07:29 PM
Sievers's Avatar
https://www.evolutionm.net/forums/ev...er-review.html
