Need Help Car Wont Start
Old May 2, 2009 | 04:11 PM
monkey_187's Avatar
I check the fuel lines and its getting fuel, I checked the spark plugs and Im not getting any spark. It will crank but wont turn over and start. What is wrong with the car, any help is appreciated.
Old May 2, 2009 | 04:14 PM
Evoryder's Avatar
fuses blown. What were you doing before or recently to the car?
Old May 2, 2009 | 04:19 PM
monkey_187's Avatar
I checked all the fuses they seem good, I hve to get a multimeter to check them really good. All I did was start the car and then it died, now it wont start. Do you know what fues would cause this?
Old May 2, 2009 | 04:52 PM
Evoryder's Avatar
look on the fuse panel anything key symbol related is ignition. Also, check your starter...have someone in the car and reach under car and tap the starter with a hammer/heavy enough tool to agitate the coils...crank the car at the same time.
Old May 2, 2009 | 08:50 PM
monkey_187's Avatar
Would the starter not working cause it not to have spark to the spark plugs? I have no spark gooing to the spark plugs.
Old May 2, 2009 | 08:53 PM
EvoPlaya31's Avatar
is this something that just started or after you installed something?
Old May 2, 2009 | 08:59 PM
monkey_187's Avatar
the car is a friends he deployed to Iraq, before he left he had cams and exhaust installed with a tune. When I started the car it was fine I tried to drive it and nly made it about 50 meters before it just died. Now it wont start at all, I do know that he put a whole bottle of fuel treatment cause he figured I would start it often.
Old May 2, 2009 | 10:27 PM
Evoryder's Avatar
any codes?
Old May 3, 2009 | 09:51 AM
mmmmbst's Avatar
Veteran: Air Force
check the cam and crank angle sensors and wires.
Old May 6, 2009 | 02:55 PM
monkey_187's Avatar
checked wire everything seems to be connected good, any other ideas?
Old May 6, 2009 | 08:29 PM
monkey_187's Avatar
Well I took of theplugs and they are all black and 2 of them are black with some red **** on them. Does anyone know what could be wrong, I will post pics of the soon.
Old May 7, 2009 | 10:03 AM
monkey_187's Avatar
Old May 7, 2009 | 11:10 AM
RoadSpike's Avatar
Excerpt from web pages:
The red coating is a result of the additives in lower-quality unleaded fuel and will be visible on the plug's ceramic insulation. The red coating is not an indication of any engine problems
Edit:
As a side note there are two fuse boxes to check one in the engine bay and one in the interior under the steering column
Old May 7, 2009 | 05:44 PM
barneyb's Avatar
To me cranking and turning over mean the same thing - that the starter is rotating the engine. And, to answer your question - the engine has to crank before it will make spark.
Old May 8, 2009 | 07:40 PM
monkey_187's Avatar
I will take the starter in for testing just to make sure, thanks
