Walbro 255lph Fuel Pump
Old May 6, 2009 | 11:39 AM
ablan029's Avatar
Anyone know how many horsepower the walbro pump is good to?? Can I push a Garrett GT30 to 30 psi with a ported head on 720cc injectors on a single walbro??
Old May 6, 2009 | 12:13 PM
xmaciek82x's Avatar
I would say around 450whp.
Old May 6, 2009 | 12:55 PM
grillpt's Avatar
I would think you should be OK as long as your running pump. You might want to consider going to a larger injector size though. I think a 255lph is good for around 500hp.
Old May 6, 2009 | 12:58 PM
Mulholland0132's Avatar
In my experience 520whp on a dynojet was the limit with 1 walboro that I saw....with 1,000cc injectors and a really high duty cylce.
Old May 6, 2009 | 01:45 PM
M4Lki3r's Avatar
Veteran: Marine Corps
Here is AEM's answer by the numbers for fuel pumps:
(Estimated HP x BSFC) x (1 + Safety Margin) = pounds/hour
pounds/hour / 7.25 = gallons/hour
gallons/hour * 3.785 = lph
BSFC refers to the efficiency of the engine. They suggest .65 to .68 for forced induction.
The recommended safety margin is .30 to give you a comfortable net to work with.
The 7.25 is the estimated weight of a gallon of fuel (gasoline) for conversion. If you are using something else (Meth, E85, Water, Nitrous, etc), this will change.
Let's assume your end goal is 500hp.
500hp x .65 x 1.3 / 7.25 = 58gal/hr * 3.785 = 220.6lph
This leaves a pretty big cushion for you to work with.
Or we could work it backwards, knowing that the Walbro outputs 255lph...
255/3.785 = 67.37gal/hr * 7.25 = 488.44lbs/hr / (1.3 x .65) = 578.04hp
So this would mean that the 255lph Walbro is good up to 578hp on gasoline with a .3 margin of safety.
Old May 6, 2009 | 01:57 PM
jid2's Avatar
Gas the 255 is OK, injectors are too small though - 880's would be better, and at that point go BIG anyway.
E85 the single pump won't work, and you need some 1200 or bigger injectors.
17579EVO9MR
Jan 29, 2017 05:03 AM
hutch959
Dec 18, 2015 05:20 PM
06EVOIXMR
11
Apr 4, 2007 05:24 PM
DizzyTT
Jun 15, 2006 06:07 PM
Megadeth2118
Lancer Aftermarket Forced Induction Tech
Nov 1, 2004 02:36 AM
