Tob help help!!!!
Old May 8, 2009 | 12:40 PM
FX11's Avatar
Tob help help!!!!
Quick question
Im about to remove tranny
How do you know if the TOB is popped out?
(I Looked thru the little hole and used the screwdriver to try prying it out)
It seems loose now but im not sure.
Old May 8, 2009 | 12:46 PM
justa4banger's Avatar
ok... have somebody pull the fork towards the drivers side and hold the fork, than stick a long flat head screw driver threw the service hole between the tob and clip, than turn the screwdriver and hold it, than push the fork towards the passanger side.... the fork should feel loose now and it should be all the way towards the paasengers side....
Old May 8, 2009 | 12:53 PM
FX11's Avatar
so basically i will know if the TOB is loose if the fork has freee play?
Case is that i thought i had it out, i went to take tranny off but it was stuck on there, i was thinking it was TOB, the Fork is forced all the way toward the driver side
i mounted the tranny back on and it is almost locked toward the driver side, i can nudge it a little but not as much as before
Old May 8, 2009 | 01:15 PM
the fork has to go all the way to the passanger side.....
Old May 8, 2009 | 01:16 PM
or you can unbolt the pressure plate from the hole where the fork sticks out..
Old May 8, 2009 | 01:36 PM
FX11's Avatar
ok i might take pics
i pushed all the way toward the driver, turned screwdriver, i then force the fork toward the passenger side. it goes about less than half way,should i give it more force? your saying the fork has to be ALL the way toward the passenger side? (i just feel like im going to break something)
unbolt it thru the rectangle hole?? its not big at all
Old May 8, 2009 | 01:43 PM
yea you can unbolt it threw the rectangle hole..ive done it a couple of times.... and if the clip is ***ed than you gona have to unbolt the pressure plate like i said before....
Old May 8, 2009 | 01:49 PM
typac69's Avatar
Yea just did this you will totally know if its off or not.. so easy but can be such a pain
Old May 8, 2009 | 01:51 PM
FX11's Avatar
Dang, is it really difficult?
Here are some pics of what it looks like now after ive been trying to get it off
Old May 8, 2009 | 02:00 PM
is the tranny all the way in again???
Old May 8, 2009 | 02:01 PM
musca999's Avatar
Putting back in you have to also be very careful not to damage the spring. I did this and had to take everything apart again as it wouldn't engage at all....total PIA!
Good luck.
Old May 8, 2009 | 02:04 PM
FX11's Avatar
Yes, i have it bolted to the block again,
how did you take out the 6 bolts thru the rectagle hole?
i just checked it out, i can probably get like 3 out, the other 3, its gona be a huge pain
FX11's Avatar
Good luck.
my new clutch is hydrolic tob =D
Old May 8, 2009 | 02:07 PM
just turn the crank
Old May 8, 2009 | 02:22 PM
FX11's Avatar
just turn the crank
wow lol i cant believe i didnt think of that
you sir = the man
lol
btw once p-plate is off, i just go on and remove tranny from the block the same way as i did with TOB method correct?
