FP Red or HTAG35R
Old May 8, 2009 | 06:18 PM
BadBoyBeltran's Avatar
FP Red or HTAG35R
Torn between the 2 turbos. Still stock valvetrain and stock bottom end but will get a ported head and engine rebuild in about 20k miles.
Fat powerband. Not too laggy. Fast. 93 octane only.
What do you guys think? Anyone got dyno sheets?
Old May 8, 2009 | 06:26 PM
DIDYSIS's Avatar
Easy HTA 35R will skool the Red.
Old May 8, 2009 | 06:32 PM
supersilverMR's Avatar
FP Red
1. Stock-like spool, sick tq at low rpm. (I made 28psi at 3800rpms with GSC 280 cams, DLL'd 442hp 402tq on pump 93 only)
2. Price 1799 for turbo, no need for a new exhaust manifold, wastegate, down pipe ect.
3. U can upgrade your valvetrain with the extra cash saved getting the Red!
gl with your build
Old May 8, 2009 | 06:39 PM
YellowEvilEvo's Avatar
TS 35R or TS HTA35R....
Old May 8, 2009 | 08:29 PM
On a different note, Anyone know what the are mods on the FP HTA 3076R dyno sheet on their site
Old May 9, 2009 | 04:10 AM
riceball777's Avatar
twin scroll htagt35r is the answer
Old May 9, 2009 | 08:06 AM
ScorpionT's Avatar
The Red is a better street turbo for quick spool, but if you want better power on 93 and dont mind spending the dough, get the twin scroll HTA 35R.
Old May 9, 2009 | 08:55 AM
cij911's Avatar
What do you consider a 'fat powerband' and what are you looking to do with your car? For me a fat powerband is 3,500 + rpms (e.g. more than 350 ft-lbs from 4,500 to 8,000 rpm). I am looking for more power myself, the car is a street car, and I would like the powerband to be in the 4,000 - 7800 range, with peak power ~ 450whp. I have been considering the FP RED and the BBK Full as I think they will meet my needs better (and cheaper) than a TS35R setup.
I also feel the 35R series turbos shine with high boost (and meth or race gas), so since you're looking for a pump fuel turbo I am guessing your boost will be less than 30 psi, which again leads me to the FP Red or BBK Full.
Best of luck
Old May 9, 2009 | 08:58 AM
Import Junky's Avatar
I agree with above poster. If you're only running pump then you should stick to RED or BBK......plus you'll gain tons of power with those two as well on meth/E-85/C16.
Old May 9, 2009 | 09:24 AM
Draven83's Avatar
What about the Tomei ARMS? i am in the same boat sorta but thinking between the red, bbk full, and the arms...
Old May 9, 2009 | 09:42 AM
cij911's Avatar
Yes this too, although I have not seen #s that would indicate it is as good as the Red or the BBK Full....
Evo8luva's Avatar
The Red seems to be making the most power between those 3 turbos, but a little slower on spool up in comparison. The bbk and arms are soo close in spool and power, somebody needs to swap those two out on a dyno and provide the results, both are pretty mean turbos though.
I would do a short runner hta35r with a .63 hot side. I think that will be the best compromise between spool and power on pump gas. And if the budget cant do a 35r setup, go with a simple Red setup. Good luck with the build.
Old May 9, 2009 | 01:37 PM
cec12789's Avatar
i vote red
Old May 9, 2009 | 01:41 PM
evoixbri's Avatar
FP RED love it. at 460whp and 402torq on 25psi with 93 pump daily driven. 4 WHEEL SLIDE TUNING ALL THE WAY !!!
Old May 9, 2009 | 04:08 PM
SRT-TO-EVO's Avatar
For what you're looking for, the Red fits the bill perfectly, and then some!!
