I can only get 1/2 lb.
Old May 8, 2009 | 10:26 PM
biggie5252's Avatar
I was supposed to go to the dyno tomorrow. I did a boost leak this evening to make sure everything was good, but I could only get about a 1/2 lb on my boost gauge (truboost) with about 28# out of my compressor. The engine was tdc and I did it from the inlet of the turbo. Everything was the same as I've always done it. There was enough flow to keep my compressor running for a while.
Well, all the air was coming out of my exhaust. I "plugged" the exhaust with a couple rags and the gauge got up to about .8 lbs. I saw a thread with basically the same symptoms a little while back but couldn't find it. So is it possible for my turbo to be leaking from the compressor to the hotside? It boosts great and hauls *** when the car is running. I haven't noticed any smoke out of my exhaust, but my windows are pretty dark. I've yet to pull any piping to see if there's any oil. As far as I know my car doesn't use a drop of oil (it never has before), but I'm going to keep an eye on it over the next several days.
Thanks.
Old May 9, 2009 | 06:24 AM
THUB's Avatar
Try turning the engine over one full time. I bet the cams have some valves open right now. (cams spin 1/2 as fast as crank) If you want to be sure, you can take off the upper timing cover and check the timing marks on the cam gears.
Old May 9, 2009 | 06:59 AM
biggie5252's Avatar
It was set to tdc using the marks on the valve cover. I've also done the test not at tdc and still got pressure.
Ill look into it a little more thoroughly though. Thanks.
