Evo 8.5 starts, then dies after 5 seconds
Subscribe
May 12, 2009 | 08:42 PM
Quote: Boscoyo, I think if the immobilizer is enabled it just want crank period but thats not the case. I could be wrong though. let me know if you know anything about it otherwise.
Yes, that is what I am to believe, also. I experienced the swap and frustration you guys speak of, except, my engine would not start at all. Before this, the information I gathered from these boards was that the engine would run without the correct code, but would shut off shortly after.
Reply 0
May 12, 2009 | 08:54 PM
Install a fuel pressure gauge and watch if it drops before it dies. It sounds like it primes on start up but might not keep running as soon as you let off the starter. Relay issue? I'm not how the wiring swap goes but might be worth to check the pump relay.
Reply 0
May 12, 2009 | 08:58 PM
eh. It idles for about five seconds and then dies. But, if you press the throttle and keep it around 3 to 4k it will stay running. It runs very sloppy, likes its missing and letting off the gas from there = instant death. Like said before, it ran fine in my viii
Reply 0
May 12, 2009 | 10:17 PM
Thanks for the replies everyone.
I'll have to look over things closer and track down the problem, I need to check over the things mentioned. Fuel pressure, electrical/fuses/circuits/relays, and make sure I pull all the codes and check the immobilizer. I'll report back once I get her running. It won't be long.
Reply 0
May 12, 2009 | 10:35 PM
Had a similar issue when I forgot to tell my tuner I had a JDM MAP sensor and he flashed the ECU with stock ROM. Doesn't sound like the issue, but just throwing it out there.
Reply 0
May 13, 2009 | 09:46 PM
She runs.....finally!!!
Thanks for all the help guys and Im sure jake appreciates it as well
Reply 0
May 13, 2009 | 10:00 PM
what was the problem?
Reply 0
May 13, 2009 | 10:24 PM
maybe the alternator? i know that if the alternator is bad the engine will shut off. maybe one of the connections to the alternator is not hooked up check fuses, relays etc. i think the 9 ecu has to have the acd with it. so did the motor come out of a 9 or 8? i dont think you can use a 9 motor with a 8 ecu.......
Reply 0
May 14, 2009 | 08:39 AM
We overlooked a plug I guess. It was to some type of relay.
Reply 0
May 14, 2009 | 07:25 PM
What a pain in the ***. One stupid plug I overlooked, the ignitor box or something? I really don't know what it's called that's what my buddy called it. Small silver box under the fuel relays and abs unit. whatever, I guess that's what I get for rushing.
Reply 0
Subscribe
