Turbo XS bov rfl evo IX
Old May 15, 2009 | 05:43 AM
visyoual's Avatar
I just bought my IX two weeks ago. Im beginning to see that vta bov's dont work without serious modification on the IX's is that correct? Or, if you do, you wind up with stall issues.
Any help is always appreciated.
thanks in advance.
Old May 15, 2009 | 08:55 AM
justa4banger's Avatar
its not about serious modifications...... you can have every single bolt on and still not be a able to put a vta bov.... you need a standalone and i forget what the other is called.... i have a aps bov and you can hear it quite enough
Old May 15, 2009 | 08:58 AM
bluebanana23's Avatar
stick with the stock DV and add an intake and should you should be content with the sound
Old May 15, 2009 | 09:02 AM
ALLSTOCK's Avatar
You need to run speed density or equivalent in order to VTA, the maf doesn't account for the air released in between shifts causing you to run rich and also causing the stalling. Switch back to the stock DV and you'll be fine.
Old May 15, 2009 | 09:11 AM
Kracka's Avatar
Keep the stock IX BOV; its more than adequate and seems to handle up to 30 lbs/boost just fine.
Old May 15, 2009 | 09:17 AM
f dat get an hks bov
Old May 15, 2009 | 09:19 AM
ALLSTOCK's Avatar
That wont help his stalling issues. He needs AEM EMS or equivalent to safely VTA
Old May 15, 2009 | 09:26 AM
kanyonkid's Avatar
keep the stocker until u get aggressive cams.. cams made mine and my buddies car's bov open during cruise and would blowoff when shifting in vacuum
Old May 15, 2009 | 09:27 AM
apparently Allstock's sarcasm detector needs its batteries changed
Old May 15, 2009 | 09:29 AM
i was being sarcastic..i guess if you knoew me you would uinderstand..lol
Old May 15, 2009 | 09:38 AM
ALLSTOCK's Avatar
Sorry... its a little early, and im a little tired.
Note to self, 4banger uses sarcasim
Old May 15, 2009 | 10:05 AM
im freaking mexican dude i play around all day
Old May 15, 2009 | 10:06 AM
lmao
atleast you understood
Old Aug 5, 2009 | 07:45 AM
visyoual's Avatar
i need marktplace access
Old Aug 5, 2009 | 07:46 AM
visyoual's Avatar
so close...
fugiwara
Jun 1, 2016 02:13 AM
Evilutiondreamz
Sep 12, 2014 11:03 AM
ibarkovic
32
Aug 3, 2008 08:32 PM
Mitchubishievo
Aug 31, 2007 10:41 AM
E VOL IX
Aug 31, 2006 10:34 PM
