HELP! Tranny from Block:how?
Old May 16, 2009 | 10:53 AM
NJ_EveOhVIII's Avatar
This is where im at right now. everything was pulled together. ALL the bolts are out of the tcase and the tranny. Is the tranny just resting on the spline and i need just a good yank. Is there a Fork in the tranny that i cant find? some input would be great trying to get these apart.
Old May 16, 2009 | 10:54 AM
Johnboy1065's Avatar
you probably have not released the TOB from the pressure plate, if you have done that though, then give it a good yank
Old May 16, 2009 | 10:55 AM
dsevo's Avatar
You have to pop the throw out bearing. I've never done it but I'm sure someone will chime in how to do it. Or if you search tob it should come up.
Old May 16, 2009 | 11:04 AM
5ULW610's Avatar
Registered User
yeah just looks like you need to pop the TOB
Old May 16, 2009 | 11:06 AM
took the Rubber gromet out and i wedge a flat head up in there to release the fork/TOB? that simple?
Lukelis's Avatar
I do this two days
Old May 16, 2009 | 11:38 AM
how do i undo the "arm" that is attached to the TOB. theres a giant spring and an "arm" hold the TOB in place how do we get under there and take the hook off to do all this.
Old May 16, 2009 | 11:40 AM
Originally Posted by Lukelis
I do this two days
is this:
I do this today?
i do this in 2 days?
I did this 2 days ago?
which?
Old May 16, 2009 | 11:44 AM
kanyonkid's Avatar
i dont remember if i "released" the TOB... i think i jus used a flatbar to pry it away and as soon is it broke loose it came right out.... i've done this once and it was about 8 months ago
Old May 16, 2009 | 11:50 AM
EatSleepBoost's Avatar
use a flat head to release the throw out bearing. when it is released the fork will pop to the right and free up. then pull the tranny n motor apart
Old May 16, 2009 | 01:26 PM
another prob i had when i took the tranny bolts off. it went sideways. now its just a PITA to get it upright. and the Tcase still wont budge out any other suggestions to get that out first?
Old May 16, 2009 | 01:33 PM
moreryce's Avatar
you need to set the tranny back in its original place and put a bolt or two to hold it there... then you can stick a flat head inside the bottom inspection hole and put it in between the throw out bearing and the preasure plate... then release it...
it will take a bit of muscle but just make sure you push the lever into the preasure plate.. then at the same time you are prying.. pull it out along witht the bearing and the bearing should release...
If that doesnt work... get a 1/4 ratchet with a 3-4in extension with a 12mm at the end and stick it in where the fork is and detatch the preasure plate by removing each bolt one at a time while turning the motor...
Old May 17, 2009 | 06:38 AM
sounds like you didnt take the output shaft out that links the transmission to the transfer case.
Old May 17, 2009 | 06:54 AM
03lan-evo's Avatar
LOOK AT STEP 14 and 21
http://www.evomoto.com/tech_info.php...3_4&tech_id=27
Old May 17, 2009 | 09:54 AM
dtuned's Avatar
Look at this and see where the screwdriver is inserted between the wdge collar and TOB
https://www.evolutionm.net/forums/ev...t-bearing.html
Insert screwdriver accordingly, and with the other hand, push the lever all the way towards the engine. Put some a$$ into it. Now turn the screwdriver 90 degrees. The wedge collar will come off and the lever will relax and go fully towards the engine. It may take a few times, so be patient.
As for the other stuff i see, jack that cherry picker up a bit more and rest the engine on something to take the weight off so that you can rotate the tc/gearbox back to the correct position. Also, rest it on something to take the weight off of it safely. If you have not already released the TOB, do it now. Finally, take a flathead screwdriver, insert between the gearbox and engine and start working the gearbox away from the engine, from left to right up top and on the bottom or vice-versa. Try not to drop the gearbox when it finally is off the engine. Get someone to assist you, if possible.
