Gay boosting prob...need advice.
Old May 16, 2009 | 03:00 PM
MattyBoyMR's Avatar
Ok well here whats happening.
1st and 2nd gear ill spike 27psi, im tuned for 27. Then it will drop back to 19psi. But as soon as i hit 3rd 4th and 5th...its just a steady 19 psi. Im running a AEM tru boost. Do yall think its my wastegate placement? its off the merge collector on the manifold....Im running a gt35r with a tial 38mm wg, with 18psi spring, boost leaked it and it was all good and yes still stock ecu
Old May 16, 2009 | 03:30 PM
Evo8Emperor's Avatar
You dont give enough information like what turbo set up your running or what boost control method your using also. Also what lbs spring in your waste gate so you know what waste gate boost is ? Also still using the stock ecu ?
boost leak test is always the easiest and cheapiest thing to do first before anything.
Old May 16, 2009 | 05:01 PM
C6C6CH3vo's Avatar
If there's a spring loaded boost controller going to the ext WG, then the bleed could be clogged
