Car wont boost...help!
Old May 18, 2009 | 06:59 PM
wtbEVO9's Avatar
Hey guys a few days back a friend of mine and I installed a few items on the car. Before that, the car was boosting just fine. Here are the modifications we installed:
Ported Intake Mani
Ported Exhaust Mani
Ported Throttle Body
3.5 inch FMIC
UICP(Still using stock 9 bov)
LICP
AEM intake
Megan 02 Housing
255 Walbro
before the car had:
turboback
and another intake
AEM TRU BOOST.
HERE IS THE PROBLEM:
The idle is perfect with an appropriate AF readings. However, when we try to go into boost, it won't go past 2-3 psi and it makes a flutter noise and AF would go all the way lean. What we tried to do is connect the wastegate and boost lines together to see if it would at least boost wastegate pressure but the car still had the same problem. Any help would be appreciated.
Thanks!
Old May 18, 2009 | 07:03 PM
kanyonkid's Avatar
intercooler pipe came off, or maf isnt plugged in
Old May 18, 2009 | 07:13 PM
huevosrancheros's Avatar
that happened to me one time
the car idled like utter crap and would not boost. One I pluggedt he maf back in , gravy.
Old May 19, 2009 | 12:26 AM
sekula's Avatar
The car idles perfectly, and I already did a boost leak test and no boost leaks came up. Also, the MAF is plugged in, it's nothing obvious like that.
Old May 19, 2009 | 11:26 AM
wtbEVO9's Avatar
bump for answers! Having an Evo that doesn't boost is like having a big ***** with erectile disfunction.
Old May 19, 2009 | 12:36 PM
srcevo8's Avatar
With "no boost" you should be hitting wastegate pressure at like 10-11psi. So to only see 2-3psi seems more like your ECU is totally confused by all of the breathing mods you put on. The weirdest part to me is the normal idle.
Old May 19, 2009 | 12:45 PM
cij911's Avatar
Sounds like your Walbro installation went awry (bad) or there is an issue with the AEM intake (with the MAF sensor)...Log the car while trying to boost so you actually have data, but my guess is you have insufficient fuel pressure...
So since you have another intake try that one again and see what happens....If the problem is still there then try putting the stock fuel pump back in and see what happens...
Old May 19, 2009 | 01:58 PM
wtbEVO9's Avatar
the code that comes up is p0243 which is "turbo/wategate set up"...we checked everything and it all set up looks good
Old May 19, 2009 | 02:10 PM
cij911's Avatar
does the compressor spin freely ????
Old May 19, 2009 | 02:24 PM
sparky's Avatar
So, did you try running a hose directly from the nipple on the compressor housing discharge tube to the port on the WGA? Be sure to plug off the open hose ends that go to the MBC, etc.
Now, try increasing boost by rotating the turnbuckle on the threaded end of the adjustable actuator rod inward(clockwise if looking at the WGA while standing at the passenger side fender and facing in toward the engine compartment). Give it about three full 360* rotations to start with.
Old May 19, 2009 | 05:58 PM
EatSleepBoost's Avatar
yea check ur turbo to make sure it spins freely. also do some research and find the pic of all of the factory vaccum lines and make sure you have everything routed correctly
Old May 19, 2009 | 11:23 PM
wtbEVO9's Avatar
yes!
I believe that the fuel pump is busted...I am getting it diagnosed by a shop tomorrow and will keep this thread updated in case someone else might be having similar problems.
Old May 19, 2009 | 11:25 PM
wtbEVO9's Avatar
i have an EBC
Old May 20, 2009 | 05:17 AM
musca999's Avatar
Yep...sounds like intercooler pipe. Happened to me just I was gonna launch. Loud POP and no boost. Sounded alot scarier than it ended up being!
Old May 20, 2009 | 05:20 AM
CAD EVO's Avatar
You wouldnt build any boost at all with the intercooler pipe off.
