6spd build.
6spd build.
I'm afraid it has come time for me to have my transmission rebuilt. I don't want a 5spd because I like my overdrive on the 6spd. Is there any solution to getting a stronger 6spd or do I have to go back to the stock internals? I'm fine with going back to stock as I am absolutely not going to a 5spd. My car has evey bolt on and headwork, minus he fpred which will go on later this year.
send it to tre or shep. they both do great work. here are their sites.
http://www.teamrip.com/
http://www.sheptrans.com/
you know, 6th gear crusing only gives you like 100-maybe 200 rpm lower then a evo8 5speed in 5th.... go to mfactory's website and play with the gear ratio calculator, plug in the 6speed ratios and the 5speed ratios and take a look.
like said above, TRE or Shep can help you out.
