Urgent
Old May 20, 2009 | 03:43 PM
06EvoIX's Avatar
Urgent
all three of my acd lights came on while driving... i have an 06 evo ix.. what does this mean? i have 57k on it.. and modded. never seen this before.. keeps coming on when i start car.
Old May 20, 2009 | 04:36 PM
Kracka's Avatar
Step 1: Post in the correct section of the forum.
Step 2: Read your owner's manual.
Step 3: Make sure your ACD reservoir isn't empty.
More than likely its an error in your ACD ECU for whatever reason, but if the above don't fix your issue your ACD system may be in need of bleeding. Was your clutch done recently?
Old May 20, 2009 | 06:15 PM
06EvoIX's Avatar
my clutch was done about a year ago. ill check the resevoir tomorrow. but the thing is i just brought it to pep boys for an oil change and then this happens after i get it back... five times in a row from turning off the car.
Old May 23, 2009 | 11:50 AM
MR_Evo_Rob's Avatar
Unfortunately, mine will do the same thing. It happens once about every 4 months. When I see all the lights on, I just turn the car off, wait a few seconds, start it up, and go.
Old May 23, 2009 | 12:30 PM
awdturbo8's Avatar
i had the same problem also.i have an ems so idk if that's what causes it but if i turn the car off for a few minutes and turn the key forward until the three lights turn off and start it,its all good after that.my fluid is full and i bled the ACD twice
Old May 23, 2009 | 02:51 PM
EvolNinja's Avatar
I have the same thing too. I already tried bleeding the ACD but no help. I've been running it those lights on and it's very annoying. I'm going to take it to the dealer to check it since I'm still under warranty. At least that's what the service tech said. Otherwise, I'm going to get the Non-ACD transfer case when it goes out.
Old May 23, 2009 | 02:54 PM
silver9mr's Avatar
yea same problem here but the lights dont go on all the time tho
