compression
Old May 20, 2009 | 06:11 PM
deathangel1812's Avatar
compression
im learning more and more about cars. can someone give me the rundown about compression please
Old May 20, 2009 | 07:51 PM
barneyb's Avatar
For example, if your car has a 9:1 compression ratio that means there is 9 times more room in the cylinder when the piston is down than when the piston is up. Engines with higher compression ratios (10:1 is higher than 9:1) make more power but suffer from knock. Higher octane gasoline is used to avoid knock.
Adding a turbocharger is just like increasing the compression ratio. That is why many of the modifications done to our higher output engines are in an effort to avoid knock.
Old May 21, 2009 | 10:28 PM
compression
oh ok thank u
