Need help with oil leak!
Old May 24, 2009 | 09:40 AM
03blkevo's Avatar
I stripped the banjo bolt for oil feed line. The one that goes from the head directly to the turbo. Well it leaks a lil bit does any1 have suggestions on what my course of action should be.
Old May 24, 2009 | 12:18 PM
guapoholic's Avatar
You might get more responses if you posted it in another section...
Old May 24, 2009 | 01:01 PM
houdini_678's Avatar
Good Luck!!!
Old May 24, 2009 | 01:07 PM
BlueDemon's Avatar
Suggestion/Recommendation: Buy another banjo bolt.
Case Closed.
Old May 24, 2009 | 01:10 PM
lemmysports2's Avatar
Originally Posted by bluedemon
suggestion/recommendation: Buy another banjo bolt.
Case closed.
+1
Old May 24, 2009 | 04:28 PM
03blkevo's Avatar
Case Closed.
did that! still leaking, i retapped the hole, still leaking!
really what other section this is ENGINE and TURBO.
Old May 24, 2009 | 06:20 PM
guapoholic's Avatar
IDK.. Maybe the engine and turbo section in Lancer Evo 1-9 with more viewers/potential help while still having your question remain relevant. Just a suggestion wise-guy. Good look with your leak. Hope your motor blows up and the piece of metal from the head blows through the dash and into your skull.
Old May 25, 2009 | 11:44 AM
DemonTweaks's Avatar
New bolt and fresh threads in the head?
New copper washers too?
Is the bolt going in straight? (you didn't cross thread it when you chased it?)
Could be the surfaces on the banjo ends on the tube, or a small crack in it. You have to look it over real thorough.
Try to find aluminium washers, they are softer and comforms better.
Old May 26, 2009 | 09:56 AM
03blkevo's Avatar
New washer new bolt fresh threads all check. the bolt went in straight, i will probably look for another banjo bolt. but now is there a risk of ****ing up the head more?
dude calm down, this isnt really a topic for dumb answers, like use glue, or some high temp epoxy, this is actually a problem that could as u well put, blow my motor, so i would like some1 who knows a lot about alum heads and repair tactics of a pretty delicate situation, now to your whole piece of metal in my skull thing karma is a ***** and getting upset over the internet is utterly useless.
Old May 26, 2009 | 10:01 AM
ev0lution9's Avatar
yeah chill with the wishing people with death or whatever...only thing he was suggesting which was right get out of this advanced section because for some weird reason not as many people look here go back to evo 1-9 section and go to engine/turbo/drivetrain...now im not being a dick im just trying to settle this and help you get some answers
Old May 26, 2009 | 10:09 AM
03blkevo's Avatar
thank you ev0, i will repost in the other section. maybe i will get other responses i just hope they arent dumb ones
Old May 26, 2009 | 10:36 AM
ev0lution9's Avatar
no problem... you shouldnt get dumb answers i cant pinpoint your problem either
Old May 26, 2009 | 03:01 PM
tscompusa2's Avatar
try using teflon tape yet?
Edit: Just be careful using that, if you do use it make sure it remains on the threading and doesn't slide down and clog the hole.
Old Jun 11, 2009 | 05:35 PM
turbogst311's Avatar
teflon will do the job.
Old Jun 15, 2009 | 11:47 PM
huevosrancheros's Avatar
Ziiiiiiinnnnnnnnnnngggggggg.
Maybe wrap up that banjo bolt in some teflon
works for me.
