EGR Solenoid Removal + Replacement
Old May 26, 2009 | 11:10 AM
SavEVOIX's Avatar
I need to replace my EGR solenoid. I've took out the 3 vac lines and sensor. Then took out the 10mm screw from underneath it. Now i'm stuck, i don't know how to get the bracket the solenoid sits on off nor can I get the solenoid twisted off of the bracket since it looks like it screws in. Can anybody help? I can only really get one hand down there. Currently I just have my replacement solenoid plugged in and zip tied to the old one (ghetto)
Old May 29, 2009 | 12:53 PM
SavEVOIX's Avatar
bump, any guidance other than pull the motor up.
Old May 29, 2009 | 02:18 PM
boscoyo's Avatar
The solenoid bracket has two screws that you need to remove. It has one below and one above the solenoid. Feel with your hand for the screw on the bracket above the solenoid. After you remove the two screws, you will be able to access the backside of the solenoid, which is attached to the bracket by a 10 or 12mm nut.
Old Jun 10, 2009 | 08:19 PM
Evo_IX_Guy's Avatar
I just got a CEL and found out that my solenoid is going bad the problem is I have no idea where its located or what it even looks like. Could someone explain or post a pic and point it out?
Thanks in advance.
fostytou
359
Oct 23, 2025 09:54 AM
Evoguy!123
Nov 5, 2016 11:43 PM
aggieEVO
Jan 16, 2013 05:18 PM
2004EvoVIII
Oct 31, 2012 01:29 PM
MagnumVP
Lancer Engine Tech
Oct 27, 2011 03:11 PM
