Noob Question about Starter Location..
Uuuuh where is the starter? I've been looking under my hood for 30 minutes and feel totally newb.
I hear its by the intake manifold.. but I don't see it anywhere..
Why I ask is... my cars not turning over (even with a new battery!).. So I'm assuming its the starter... I can't find it though.
Usually, the Starter is on the transmission side, (drivers for Evo), on the back, below the intake manifold. Access is from underneath, and behind. I'm trying to remember seeing it, when i was under the car before.
Yea.. I actually found it a few minutes ago.. does it just have that one wire connector on the left side or is there another somewhere else on it? I mainly ask because it's dead and a friend was telling me to mess with the "wires" .. but really I was only able to feel one wire that had a connector on it.
There is a small wire that comes from the ignition switch. When the key is turned to the start position this small wire is energized and pulls in the solenoid which meshes the starter gear with the flywheel and then closes a switch connecting the battery directly to the starter through a larger cable. Then the starter motor runs. So, two wires.
