Amsoil VS Redline evo8 trans fluid need your input
Old Jun 1, 2009 | 03:15 PM
EvoDan2004's Avatar
Originally Posted by apagan01
this is what we have explainned in many threads.
we are gald the rest are catching up and noticing the same thing.
ok so what do you recommend for my type of setup?
Old Jun 1, 2009 | 03:21 PM
Protostar1's Avatar
He is going to recommend AMSoil 10W-30 in the motor, AMSoil GL-4 Tranny fluid, and AMSoil Severe Gear for the diff and transfer case as that is what he recommended and sold to me and its what you should use. I would go for it! Be prepared for a cost of $100-115.
Old Jun 1, 2009 | 03:24 PM
EvoDan2004's Avatar
i allready use amsoil oil. lol
trans ok. and t/c i wont use anything but stock.
Old Jun 3, 2009 | 05:19 PM
apagan01's Avatar
We are happy you chose AMSOIL MTG GL4 tranny fluid, your oil should be on its way to Dog Box company transmission shop.
ok well with how crappy the search function is on this forum i need to make another thread.
i am getting my trans rebuilt and everything will be new. so i want to start it off with the right fluid. im not interested in anything other then the 2 brands i just mentioned. so there is no need to recommend anything else to me.
the car is used for weekend drag racing and mainly highway fun. i only want info from guys who are making big numbers/fast track times and really beat the **** out of there car/trans. anyone else need not apply. hard core track guys are also welcome..all i want to know is what your using and how do you like it. also explain your trans setup/builder and miles you have been using one of the brand fluids i am interested in.
also what viscosity ''spell check'' are you using or model fluid should i say??
SHOP GUYS. please post up. im more interested in your guys input then anyone else.
NOTE... i know a dead cold trans with thick fluid does not shift well. i dont care about that as i never drive the car till its warmed up anyway. thanks to those who can help.
Old Jun 3, 2009 | 05:28 PM
apagan01's Avatar
I think evodan is puhing some high numbers powerwise, since i talk to Jestr alot and we talk about all the good cars he tunes and evodan is one of those.
since evodan is pushing high power a 10w30 maybe not, we would have to step it up to a 40 maybe a 50.
maybe he would benefit from using racing oil.
Old Jun 3, 2009 | 05:34 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
My engine oil, tranny, transfer case, and rear diff all Amsoil
Old Jun 4, 2009 | 02:53 AM
tony gibson's Avatar
Originally Posted by S2kracka
I've tried a lot of fluids and have yet to find one better than the Redline MT-90/MTL mix. Its all I ever recommend to people and everyone seems to like it. My car sees daily-driven abuse plus autocross.
I agree with this guy...I use the same mix and with 83,000 miles on the stock tranny, I drained the fluid the other day and there were only minor metal hairs on part of the magnet...The car sees 20,000 hard miles a year and runs low 11 sec. passes on an FP Green and AEM EMS with all supporting mods...If I reach over 600whp I may switch to Light Weight Shock Proof.
Old Jun 4, 2009 | 06:53 AM
kouzman's Avatar
Motor I currently use amsoil signature 0w30 which is by far better than the stock mobil 1 or redline.
Tranny however I am using redline mt-90 on my shep built tranny, oem qiaqueen in the transfer case and redline heavy shockproof in the rear diff.
Next time I might try the mt-90 / mtl mix.
Old Jun 4, 2009 | 08:20 AM
itzwolf's Avatar
John Shepherd personally recommended the Lightweight Shockproof fluid for my 2nd transmission rebuild for the power I was aiming for/making. Originally it was only MT90 to be used. The Lightweight Shockproof has been in the car for a year and I have had no issues. I do have a 5th gear grind that started fairly quickly after the rebuild but John said there is a chance it would come back being a common problem with Evo's but every other gear has been solid smooth and perfect shifts. I don’t exactly shift slow either which was another reason for the recommendation. I lift to shift every time but in a video you would beg to differ on that statement
I do realize the information from Team RIP and it makes perfect sense, but my car isn’t daily driven it’s a weekend only car and gets some fair abuse when driven so I went with what would protect the gears the most. My realization is that I would need to rebuild it before that potential problem would become true. I am on my 2nd Shep transmission, the first died from several lower clutch line (the solid line) failures and synchros getting destroyed.
I have tossed the idea of trying AMSOIL in the transmission but haven’t really made up my mind for that yet. I do run the AMSOIL 15w50 Racing Oil in the engine it is has been a great fluid, I am very impressed with it.
Old Jun 4, 2009 | 11:13 AM
kouzman's Avatar
How much power are you making?
I am changing my setup currently and I will be looking 600awhp+++ on racegas. I will also change me engine oil since I will have to go with a heavier oil but I will probably stick with amsoil.
Now for the tranny I will only use what shepherd reccomends.
Old Jun 4, 2009 | 12:36 PM
DBallz's Avatar
I 100% agree with that. I have been using Amsoil in my motors since 02 when i boost my 00 Si and I have never had any issue I love the fact that is was much better then any other synthetic. The only over the counter synthetic i heard was good was Valvoline but that was a long time ago I don't know if that is still the case.
Old Jun 4, 2009 | 12:50 PM
itzwolf's Avatar
Hasn't been on a dyno unfortunately so I can't give you a real number, the car is street tuned by me. There really isnt many options in the Jacksonville FL area unless I go to Orlando. I have played with confirmed (dynoed) 600hp cars and I am neck and neck with them on pump gas only. I can pull a low to mid 500hp car quite easily . Never really had a reason to start running race gas yet as I dont drive it much or even play with it much lately. The car is fully built top to bottom with a 37r turbo all parts are basically from AMS and a few key componets from Buschur Racing. The detailed mod list is quite large.
I am shooting for mid 700's on race gas when that day comes.
Best option is to see what the transmission builder recommends.
Old Jun 4, 2009 | 03:49 PM
EvoDan2004's Avatar
i been using 10w30 amsoil oil in the motor. i used to use factory 10w30 m1. maybe we should talk about upgrading again to a better amsoil oil. i can pm you a mods list and goal for the car. you already know its dd and is driven very hard. let me know.
also remind me about filters. been using stock but thinking of trying a wix.
Old Jun 5, 2009 | 03:02 AM
Shep recommended the mtl/mt90 mix for my stock tranny and power level I am at...AMS oil may be a good idea for the motor though.
Old Jun 5, 2009 | 05:21 AM
kouzman's Avatar
2 quarts mt-90/1 quart mtl or 2 quarts mtl/1 quart my-90?
