Engine break-in on e85?
Old Jun 3, 2009 | 10:07 AM
Evo8's Avatar
I have to break in my new engine, and I have been running e85 for over a year now. I just want to see if it would be ok to break it in running e85 (that's what I have in the car right now). Due to my next event in 2 weeks I don't have time to switch things.
Old Jun 3, 2009 | 11:23 AM
project_skyline's Avatar
It shouldn't matter. As long as your tuned and didn't really change anything it would be the same as on pump.
Old Jun 3, 2009 | 11:31 AM
Evo8's Avatar
Yes the car has e85 tune on it. It will get retuned before the event, but it's coming out with bigger injectors (from 880 to 1200) out of the shop. So it will be broken in with bigger injectors
Old Jun 3, 2009 | 11:42 AM
Wicked E's Avatar
You may want to be damn sure those 1200's are scaled properly BEFORE you start it up. I can't tell you how bad your engine will do while washing E85 down the cylinder walls on top of the fact that the rings are not fully seated yet. I would advise sticking with the 880's to break in the motor and then get the 1200's in the day of the tune. Less chance of damage.
-E
Old Jun 3, 2009 | 11:44 AM
Jim in Tucson's Avatar
I'd suggest keeping the boost turned down to WG during the first few hundred miles or so.
High vacuum is supposed to be best for break in. Accelerate slowly then let off on gas so the high vacuum sucks the rings against the cylinder walls. Then repeat while increasing to higher rpm points.
Old Jun 3, 2009 | 12:44 PM
Evo8's Avatar
It's all fine, but I don't have that time. The event is in 2 weeks, we took the motor out today. I have to break it in and still get a tune. I don't think we're going to put 880cc back in and then swap to 1200cc. We'll have to do with 1200cc in the car. My main concern was e85 break in.
Thanks guys
QUANLOCO
E85 / Ethanol
Dec 21, 2021 09:38 PM
razorlab
E85 / Ethanol
115
Sep 14, 2019 12:28 PM
3gevoclipse
Oct 3, 2016 10:49 PM
FathouseFab
277
Aug 2, 2011 06:41 PM
Pelo
24
Aug 25, 2008 04:09 AM
