Fuel Pressure--URGENT
Old Jun 4, 2009 | 07:36 AM
dxbevo9's Avatar
hey guys...got a quick question...where does the after market fuel pressure regulator vaccum hose connect to??
thanks in advance
Old Jun 4, 2009 | 07:39 AM
dxbevo9's Avatar
the top thig that looks like an upside down "L"
Old Jun 4, 2009 | 07:51 AM
AWD_Terror's Avatar
It connect to any vaccum source. Stock source should be more than adequate
Old Jun 4, 2009 | 08:17 AM
dxbevo9's Avatar
THANKS BUD^^^
one more question...i have found a vacuum nipple on the intake mani. would it be ok if i just block it?
keep in mind that my connection are not stock due to an after market fuel pressure reg.
Old Jun 4, 2009 | 03:36 PM
AngryEvo8's Avatar
When I bought my car it had a autometer oilpressure gauge...but unfortunately it wasent hooked up to a sending unit. Any advise or how to on installing this gauge? Thanks
Old Jun 4, 2009 | 05:01 PM
SLUG LIFE's Avatar
^^^ Holy thread jack Bat-man... OP did you figure out what you need to? The FPR needs a dedicated vacuum source, if you have any extra nipples they need to be capped.
Old Jun 4, 2009 | 07:52 PM
DynoFlash's Avatar
It is always best to route the fuel pressure regulator to a direct manifold connection and also not make any T connections to the connection to minimize the likelyhood of a boost loss or other failure from the connections to effect the fuel pressure. I like to use glue and zip ties to assure a solid and reliable connection.
Al
Old Jun 5, 2009 | 07:37 AM
dxbevo9's Avatar
thanks AL....
thats what i did!!
Old Jun 6, 2009 | 05:17 AM
CO_VR4's Avatar
For anyone who does not already know, this is about the most important small line in your engine compartment in terms of risk and engine health.
The FPR or AFPR increases fuel pressure 1:1 with rising boost. The vacuum hose in question is what provides the signal to the AFPR to regulate fuel pressure. If the hose comes off under boost, the AFPR loses the signal, and does not increase the fuel pressure as it should. Instant lean engine condition = major trouble.
Make sure you use a strong system of installation methods to keep this hose where it belongs!
Old Jun 6, 2009 | 07:33 AM
dxbevo9's Avatar
do you recommend i install it into the intake manifold directly or is it ok to have it connected in a T along with the boost control solenoid?
Old Jun 6, 2009 | 12:22 PM
CO_VR4's Avatar
My personal preference is a dedicated line for the FPR, without any "T" or other joints, either to the manifold directly, or to a vacuum block with large lines feeding the block.
Jovan Caro
Feb 6, 2017 08:03 PM
clash0901
Sep 13, 2016 07:31 PM
acssa
Jan 3, 2012 09:51 AM
AWDsub
Nov 17, 2007 01:41 PM
djd24
Dec 16, 2006 12:53 PM
